I stumbled upon this problem and thought I would try to finish it (it did not get answered in the previous post), but the part with $n$ a power of two seems rather tricky. The problem is as follows:
Let $a$ and $n$ be positive integers with $a > 1$. Prove that, if $a^n+1$ is a prime number, then $a$ is even and $n$ is a power of $2$.
Suppose $a$ is odd. Then $a=2k+1$ and therefore $a^n+1$ is even, hence not a prime. So $a$ must be even.
Now, by way of contradiction, suppose that $n$ is a power of $2$ but $a^n+1$ is composite, i.e. $$a^n+1=mk$$ for some integers $m,k$. Then $a^n=mk-1$, and since $a \mid a^n$, we must have $a \mid mk-1$. Hence $ak'=mk-1$, or $ak'+1 =mk$. I was hoping this would land a contradiction, but I can't seem to find it.
I also tried proving by contrapositive, i.e. assuming that $n$ is not a power of two and then showing that it wasn't a prime, but this did not seem to bring about much.
Any ideas?
    Variants of this have been asked many times. You will perhaps find enough information here. If not, there are plenty of others. – André Nicolas Dec 14 '13 at 08:02
  • Gotcha. Didn't see how the argument with the $a$ odd applied, but letting $n=2^m k$ with $k$ odd and writing $(a^{2^m})^k$ does the trick. Very nice with $x+1 \mid x^a+1$. – Numbersandsoon Dec 14 '13 at 08:16
No problem: if n is not a power of 2 then you write n = k*2^p, with k odd then repeat your previous argument and you can show in this instant that a^n + 1 is composite because it has a^(2^p) + 1 as a factor.
DeepSea
  • 77,651
