They say that solutions of recurrence relations are combinations of exponential functions, the series like [1 a a^2 a^3 and etc].
I know that the difference operators have a matrix like
$$\begin{bmatrix} -1 & 1 & 0 & 0 & \cdots \\ 0 & -1 & 1 & 0 & \cdots \\ 0 & 0 & -1 & 1 & \cdots \\ \vdots & \vdots & \vdots & \vdots & \ddots \end{bmatrix}$$
where you have $-1 +1$ on the main diagonal. It is easy to see that any vector of the form $[1\ a\ a^2\ a^3\ a^4\ \ldots]$ is an eigenvector with eigenvalue $(a-1)$. Note that every component is $a$ times the other component. I have noted that the same is true for the solutions of difference equations. That is, as Wikipedia says, recurrence $x_n = a x_{n-1} + b x_{n-2} + \cdots$ can be represented in matrix form
$$\vec x_n = \begin{bmatrix}x_n \\ x_{n-1} \\ x_{n-2} \\ \vdots \end{bmatrix} = \begin{bmatrix} a & b & c & \cdots \\ 1 & 0& 0 &\cdots \\ 0 & 1& 0 &\cdots \\ \vdots & \vdots & \vdots & \ddots \end{bmatrix}\, \begin{bmatrix} x_{n-1} \\ x_{n-2}\\ x_{n-3} \\ \vdots \end{bmatrix} = A \vec x_{n-1}= A^n \vec x_0.$$ You can find the eigenvalues, $\lambda$, and corresponding eigenvectors, $[\ldots\ \lambda^2 y_0\ \lambda y_0\ \ y_0]^T$, of the companion matrix A. Though Wikipedia does not say that components (or, coordinates?) of the eigenvector must be multiples of each other, I think that it is the whole point of finding the eighenvectors of the companion matrix when solving the equation. It must be so because suppose $[y_{n-1} y_{n-2} y_{n-3}]^T$ is an eigenvector then $[\lambda y_{n-1}\ \lambda y_{n-2}\ \lambda y_{n-3}]^T = [y_{n}\ y_{n-1}\ y_{n-2}]$ is also elso an eigenvector and, it must be clear now that, $$y_n = \lambda y_{n-1}.$$ So, we see again that eigenvectors of recurrence relation are exponential functions, the ones we had as solutions of differential operator.
Is this right? Is there any relationship between difference operators and recurrence relationships? What does it mean that differential operator has any exponent as its eigenvector whereas recurrence of order n has n distinct lambdas and eigenvalue is (λ-1) in first case and λ in the other?
