In my homework, one problem was the following formula. Using standard partial fraction techniques where you'll see my work, I came up with an almost correct answer in the fact the book solution had a three term integral rather than the two term I used. The only difference between my work and the correct solution was I didn't rewrite the numerator. My two-part question is
- Why did excluding the numerator re-defining result in the wrong answer?
- Under what circumstances should I use numerator re-defining?
Given the following formula, integrate using partial fractions:
$$\int\frac{2x^3-4x^2-15x+5}{x^2-2x-8}$$
$$ \begin{align*} 2x^3-4x^2-15x+5=\frac{A}{x-4}+\frac{B}{x+2}\\ 2x^3-4x^2-15x+5=A(x+2)+B(x-4)\\ \end{align*} $$
Let $Ax$=-2
$$ \begin{align*} 2x^3-4x^2-15x+5=A(x+2)+B(x-4)\\ 2(-2)^3-4(-2)^2-15(-2)+5=A(-2+2)+B(-2-4)\\ 3=-6B\\ B=-\frac{1}{2} \end{align*} $$
Let $Bx= 4$
$$ \begin{align*} 2x^3-4x^2-15x+5=A(x+2)+B(x-4)\\ 2(4)^3-4(4)^2-15(4)+5=A(4+2)+B(4-4)\\ 9=6A\\ A=\frac{3}{2} \end{align*} $$
Using $A \text{ and } B$ values, plug them into the integral as
$$ \begin{align*} \frac{3}{2}\int\frac{1}{x-4}\text{dx}-\frac{1}{2}\int\frac{1}{x+2}\text{dx}\\ =\frac{3}{2}\text{ln}\left |x-4 \right |-\frac{1}{2}\text{ln}\left |x+2\right |+C \end{align*} $$
This work matches up with the solution process except the original integral was re-written as
$$\int2x+\frac{x+5}{(x-4)(x+2)}$$
which resulted in the final integral terms
$$\int2x\text{dx}+\frac{3}{2}\int\frac{1}{x-4}\text{dx}-\frac{1}{2}\int\frac{1}{x+2}\text{dx}$$
