I saw this question, and found a formula:
$$=\cos \left( d\log |a+bi|+c\arctan \frac{d}{c}\right)+i\sin \left( d\log |a+bi|+c\arctan \frac{d}{c}\right).$$
Which I later translated to Microsoft Math format:
cos(dlog(Abs(a+bi))+carctan(d/c))+sin(dlog(Abs(a+bi))+carctan(d/c))*i
And - that formula gives wrong results.
While the result is -0.507 - 0.861i
(for that formula, setting a=1,b=2,c=3,d=4
Doing (a + bi)^(c + di)
gives me 0.129+0.033i
Can anyone explain what I am doing wrong ? (I am trying to write a program which does this.)
- 191
3Taking the power of a complex number by a complex number isn't uniquely defined, as is already explained in the question you linked to. – Qiaochu Yuan Aug 08 '11 at 20:33
So how exactly does Microsoft Math calculate it ? – Mark Segal Aug 08 '11 at 20:45
Who knows? I don't even know what that is. – Qiaochu Yuan Aug 08 '11 at 20:47
2The veracity of a formula producing a complex number of modulus 1 for every (a+bi)^(c+di), as yours seems to be doing, is highly dubious. Another, similar, remark is that your formula gives 1 for every (a,b,c,d) such that d=0. Hmmm... – Did Aug 08 '11 at 20:56
That wasn't my formula but Americo Tavareses... – Mark Segal Aug 08 '11 at 21:15
No it is not: you forgot the $e^{c\log∣a+bi∣−d\arctan(d/c)}$ part. – Did Aug 08 '11 at 21:22
But there are some (other unrelated) problems with Americo's formula. – Did Aug 08 '11 at 21:24
@Didier Piau: I corrected the formula in my answer as per Ross Milikan's comment. – Américo Tavares Aug 08 '11 at 21:58
Correction: $$\begin{eqnarray} \left( a+bi\right) ^{c+di} &=&e^{(c+di)\left( \log \left\vert a+bi\right\vert +i\arctan \frac{b}{a}\right) } \ &=&e^{c\ln \left\vert a+ib\right\vert -d\arctan \frac{b}{a}}e^{i\left( d\ln \left\vert a+ib\right\vert +c\arctan \frac{b}{a}\right) } \ &=&e^{c\ln \left\vert a+ib\right\vert -d\arctan \frac{b}{a}}\left( \cos \left( d\ln \left\vert a+ib\right\vert +c\arctan \frac{b}{a}\right) +i\sin \left( d\ln \left\vert a+ib\right\vert +c\arctan \frac{b}{a}\right) \right) \end{eqnarray}$$ – Américo Tavares Aug 08 '11 at 22:19
It doesn't yield the same result Mathematica 8 does. Playing around with Expand gave me this formula: ((a + bI)^2)^((c + dI)/2) Cos[(c + dI) Arg[a + bI]] + I ((a + bI)^2)^((c + dI)/2) Sin[(c + dI) Arg[a + bI]] – Mark Segal Aug 08 '11 at 23:06
Wait - that doesn't even helps me. God damn it – Mark Segal Aug 08 '11 at 23:33
And I corrected the formula once more: $$\begin{eqnarray} \left( a+bi\right) ^{c+di} &=&e^{(c+di)\text{ Log }(a+bi)} \ &=&e^{(c+di)\left( \ln |a+bi|+i\arg (a+bi)\right) } \ &=&e^{c\ln \left\vert a+ib\right\vert -d\arg \left( a+ib\right) +i\left( c\arg \left( a+ib\right) +d\ln \left\vert a+ib\right\vert \right) } \ &=&e^{c\ln \left\vert a+ib\right\vert -d\arg(a+bi)}\times \ &&\times \left( \cos \left( c\arg \left( a+ib\right) +d\ln \left\vert a+ib\right\vert \right) +i\sin \left( c\arg \left( a+ib\right) +d\ln \left\vert a+ib\right\vert \right) \right). \end{eqnarray}$$ – Américo Tavares Aug 09 '11 at 10:26
I don't see what this adds to the linked question (and many others linked there) -- voting to close as too localized. – Grigory M Aug 09 '11 at 11:11
I am sorry for the errors in my answer. I revised it. Would you mind using the revised formula? I detailed the computation for your case $a=1,b=2,c=3,d=4$ and for $a=-1,b=2,c=3,d=4$ and both results agree with the computations performed in Wolfram Alpha. – Américo Tavares Aug 09 '11 at 11:20
In the present case $\arctan 2/1=\arg(1+2i)$ (the principle argument of $(1+2i)$. However, since in general it may be different, e.g. $\arg(-1+2i)=\arctan(-2)+\pi=-\arctan 2+\pi$, I revised my answers and used only $\arg(a+bi)$. – Américo Tavares Aug 09 '11 at 11:37
@Didier Piau: I corrected the formula once more. Now it should be right. – Américo Tavares Aug 09 '11 at 14:57
The formula you cite is in Américo Tavares' response to the question. I believe the argument of the $\arctan$ should be $\frac{b}{a}$. When I plug it into Wolfram Alpha with your constants, I get about $0.9671+0.2543i.$ It is the exponential of only the imaginary part, so you need to multiply it by the exponential of the real part: $e^{c\log |a+bi|-d\arctan \frac{b}{a}}\approx 0.1333$ if you expect $(1+2i)^{(3+4i)}$ and it comes out.
- 374,822
Just an information. In the present case $\arctan 2/1=\arg(1+2i)$ (the principle argument of $(1+2i)$. However, since in general it may be different, e.g. $\arg(-1+2i)=\arctan(-2)+\pi=-\arctan 2+\pi$, I revised my answers and used only $\arg(a+bi)$. – Américo Tavares Aug 09 '11 at 11:35
I corrected the answer you cite. Instead of the $\arctan$ function it should be the $\arg$ function. These two functions are not always equal. The $\arg$ function is used in the principal logarithm of $z=x+iy$, which is the complex number
$$w=\text{Log }z=\log |z|+i\arg z$$
so that $e^w=z$, where $\arg z$ (the principal argument of $z$) is the real number in $-\pi\lt \arg z\le \pi$, with $x=|z|\cos (\arg z)$ and $y=|z|\sin (\arg z)$.
The formula now reads as follows:
$$\begin{eqnarray*} \left( a+bi\right) ^{c+di} &=&e^{(c+di)\text{ Log }(a+bi)} \\ &=&e^{(c+di)\left( \ln |a+bi|+i\arg (a+bi)\right) } \\ &=&e^{c\ln \left\vert a+ib\right\vert -d\arg \left( a+ib\right) +i\left( c\arg \left( a+ib\right) +d\ln \left\vert a+ib\right\vert \right) } \\ &=&e^{c\ln \left\vert a+ib\right\vert -d\arg(a+bi)}\times \\ &&\times \left( \cos \left( c\arg \left( a+ib\right) +d\ln \left\vert a+ib\right\vert \right) +i\sin \left( c\arg \left( a+ib\right) +d\ln \left\vert a+ib\right\vert \right) \right). \end{eqnarray*}$$
For $a=1,b=2,c=3,d=4$, we have (numeric computations in SWP)
$$\begin{eqnarray*} \left( 1+2i\right) ^{3+4i} &=&e^{(3+4i)\text{ Log }(1+2i)} \\ &=&e^{(3+4i)\left( \log |1+2i|+i\arg (1+2i)\right) } \\ &=&e^{3\ln \left\vert 1+2i\right\vert -4\arg \left( 1+2i\right) +i\left( 3\arg \left( 1+2i\right) +4\ln \left\vert 1+2i\right\vert \right) } \\ &=&e^{3\ln \left\vert 1+2i\right\vert -4\arg \left( 1+2i\right) }\times \\ &&\times \left( \cos \left( 3\arg \left( 1+2i\right) +4\ln \left\vert 1+2i\right\vert \right) +i\sin \left( 3\arg \left( 1+2i\right) +4\ln \left\vert 1+2i\right\vert \right) \right) \\ &\approx &0.13340\left( \cos \left( 6.5403\right) +i\sin \left( 6.5403\right) \right) \\ &\approx &0.12901+3.3924\times 10^{-2}i, \end{eqnarray*}$$
which agrees with the computation in Wolfram Alpha for $(1+2i)^{3+4i}.$
And for instance, if $a=-1,b=2,c=3,d=4,$ then
$$\begin{eqnarray*} \left( -1+2i\right) ^{3+4i} &=&e^{(3+4i)\text{ Log }(-1+2i)} \\ &=&e^{(3+4i)\left( \log |-1+2i|+i\arg (-1+2i)\right) } \\ &=&e^{3\ln \left\vert -1+2i\right\vert -4\arg \left( -1+2i\right) +i\left( 3\arg \left( -1+2i\right) +4\ln \left\vert -1+2i\right\vert \right) } \\ &=&e^{3\ln \left\vert -1+2i\right\vert -4\arg \left( -1+2i\right) }\times \\ &&\times \left( \cos \left( 3\arg \left( -1+2i\right) +4\ln \left\vert -1+2i\right\vert \right) +i\sin \left( 3\arg \left( -1+2i\right) +4\ln \left\vert -1+2i\right\vert \right) \right) \\ &\approx &3.267\,9\times 10^{-3}\left( \cos \left( 9.3222\right) +i\sin \left( 9.3222\right) \right) \\ &\approx &3.\,250\,7\times 10^{-3}+3.346\times 10^{-4}i. \end{eqnarray*}$$
In Wolfram Alpha we get $(-1+2i)^{3+4i}\approx -0.003250688+0.000334598i$
- 38,602
@Quantic Programming: You are welcome! Sorry for the errors in my old answer! – Américo Tavares Aug 09 '11 at 11:43
