Another homework problem from my Group Theory class.
Let $a,b$ be elements of a group, $G$. Let $\operatorname{ord}(a)=m$ and $\operatorname{ord}(b)=n$.
Let $a$ and $b$ commute. Prove: If $m$ and $n$ are relatively prime, then the $\operatorname{ord}(ab)=mn$.
So I am having trouble starting off on this problem. Here is what I believe I know:
$a^m=e$ and $b^n=e$ [as defined by the order of the elements] which leads $a^m=b^n$
$\operatorname{ord}(ab)=mn=\operatorname{ord}(ba)=nm$ as defined by commuting.
$\gcd(m,n)=1$ as defined by $m,n$ being relatively prime.
I don't know how to start this proof.
Do I want to to go the route of $a^mb^n=e$? Then $(ab)^{mn}=e$?
Any tips to start this would be greatly appreciated!!!
  • It suffices to show that all multiples of $m$ and $n$ annihilate $ab$. Because then the least one (which is the order) is the LCM. – Henry Swanson Nov 08 '13 at 00:34
  • Show that $ord(ab)|mn$ because $(ab)^{mn}=a^{mn}b^{mn}=e$. So $ord(ab)\leq mn$. Then show that $mn\leq ord(ab)$ – Haha Nov 08 '13 at 00:36
$\newcommand{\ord}{\operatorname{ord}}$ Note that by commutativity, $(ab)^n=a^nb^n$. If $a^nb^n=1$ then $a^n=(b^{-1})^n\in \langle a\rangle\cap \langle b\rangle \leq \langle a\rangle,\langle b\rangle$ so what can you conclude about $n$ and the orders of $a,b$ which are the orders of $\langle a\rangle,\langle b\rangle$?
ADD The above gives $\ord a,\ord b\mid n$, so their $\rm lcm$ i.e. their product by coprimeness divides $n$. But if $k$ equals the product of the orders it is immediate $(ab)^k=1$.
Pedro
  • 122,002
Note that $(ab)^d=e$ if and only if $m\mid d$ and $n\mid d$.
BlackAdder
  • 4,029
Here is a proof for $\mathbf{Z}/m\mathbf{Z}$, I believe the proof is nearly identical for an Abelian group $G$. Let $o(a)=h, o(b)=k, o(ab)=r$. We have $(ab)^r\equiv 1\pmod{m}, a^h\equiv 1\pmod{m},$ and $b^k\equiv 1\pmod{m}$. Consider $(ab)^{hk}$. We have $$(ab)^{hk}=a^{hk}b^{hk}=(a^h)^k(b^k)^h\equiv 1\pmod{m},$$ so $o(ab)|hk\implies r|hk$. We also have $b^{rh}\equiv (a^h)^rb^{rh}\equiv (ab)^{rh}\equiv 1\pmod{m}$, so $k|rh$. Since $\gcd(k,h)=1$, $k|r$. Similarly, $h|r$. Thus, there are integers $\alpha,\beta\in\mathbf{Z}$ such that $r=h\alpha=k\beta$. Moreover, by Bézout's lemma, there are integers $x$ and $y$ such that \begin{align*}&\phantom{\implies} xh+yk=1\\ &\implies rxh+ryk = r\\ &\implies k\beta xh+h\alpha yk = r\\ &\implies hk(\beta x+\alpha y) = r,\end{align*} so $hk|r$. Thus we have $r|hk$ and $hk|r$, so $r=hk$, as desired.
tc1729
  • 3,017
