Let $R$ be a commutative ring, and let $\{f_i\}$ be a finite set of elements generating the unit ideal in R. Then $\{f_i^N\}$ also generate the unit ideal in $R$, for any positive $N$.
Why is this true?
Why is this true?
If $\{f_i\}$ generates $R$, then write $$ 1=\sum_{k=1}^Ma_kf_k $$ where $a_k\in R$. Then raise this monstrosity to the power of $MN$. Then every term has some $f_k^N$ or a higher power in it. Appropriate rearragement shows that $1$ is in the span of $f_k^N$.
Any prime ideal containing $f^n$ contains $f$. Therefore, any prime ideal containing $I=\left<\{f_i^n\}\right>$ contains $R$. This is absurd, and therefore there is no prime ideal containing $I$, and this implies $I=R$.
