I'm reading Bernt Oksendal's "Stochastic Differential Equations" and "adapted" is one of the concept that I could not understand.
First, "adapted" is defines at Ch3.1, page 25 (sixth edition):
Definition 3.1.3. Let $\{\mathscr{N}_t\}_{t\geq 0}$ be an increasing family of $\sigma$-algebras of subsets of $\Omega$. A process $g(t,\omega):[0,\infty)\rightarrow \mathbb{R}^n$ is called $\mathscr{N}_t$-adapted if for each $t\geq 0$ the funcction $$\omega\rightarrow g(t, \omega)$$ is $\mathscr{N}_t$-measurable.
Then, it says:
Thus the process $h_1(t,\omega) = B_{t/2}(\omega)$ is $\mathscr{F}_t$-adapted, while $h_2(t,\omega) = B_{2t}(\omega)$ is not $\mathscr{F}_t$-adapted.
Here $B_t$ is Brownian motion.
I'm lost. Brownian motion means the particle can appear at anywhere, right? Let's just consider $n=1$, a 1-dimension Brownian motion can take any value for x, just the bigger $x$ is, the smaller the probability.
So I thought Brownian motion is just defined on $\mathscr{B}(\mathbb{R})$, the Borel $\sigma$-algebra on $\mathbb{R}$, for any $t$. So both $h_1(t,\omega) = B_{t/2}(\omega)$ and $h_2(t,\omega) = B_{2t}$ are defined on $\mathscr{B}(\mathbb{R})$, always measurable, so always adapted?
Here $\mathscr{F}_t$ is defined earlier:
Definition 3.1.2. Let $B_t(\omega)$ be $n$-dimensional Bownian motion. Then we define $\mathscr{F}_t = \mathscr{F}_t^{(n)}$ to be the $\sigma$-algebra generated by the random variables $B_s(\cdot); s\leq t$. In other words, $\mathscr{F}_t$ is the smallest $\sigma$-algebra containing all sets of the form $$\{\omega; B_{t_1}(\omega) \in F_1, \cdots, B_{t_k}(\omega) \in F_k\}$$, where $t_j\leq t$ and $F_j \subset \mathbb{R}^n$ are Borel sets, $j\leq k=1,2,\ldots$ (we assume that all sets of measure zero are included in $\mathscr{F}_t$).
