The following exercise is from Gallian's Contemporary Abstract Algebra:
Show that every nonzero element of ${\bf Z}_n$ is a unit of a zero-divisor.
A unit of a ring is an element which has a multiplicative inverse. A nonzero element $a$ is a commutative ring $R$ is called a zero-divisor if there is a nonzero element in $R$ such that $ab=0$.
Here is my question:
What is a unit of a zero-divisor in this exercise?
Edit:
According to the answers, this is a typo.
  • I deleted my comment and moved it to an answer, along with a link to a hint (after recalling that you were the author of the related prior question). – Bill Dubuque Jul 04 '11 at 03:56
It should say "unit OR a zero-divisor". The proof follows immediately from your prior exercise and an application of Bezout's GCD identity to deduce that $\rm\ gcd(m,n)=1\ \Rightarrow\ m\ $ is a unit in $\rm\:\mathbb Z/n\:.$
Bill Dubuque
  • 272,048
I think the question is stated wrongly. It should be:
Show that every nonzero element of $\mathbb{Z}_{n}$ is a $\text{unit or a zero-divisor}$.
Solution. Suppose that $a \in \mathbb{Z}_{n}$. If $\text{gcd}(a, n) = 1$, then we know that $a$ is a unit. Suppose that $\gcd(a, n) = d > 1$. Then $a(n/d)= (a/d)n = 0$, so $a$ is a zero-divisor.
  • Why does gcd$(a,n)=1$ imply $a$ is a unit? Are you using the property of the congruence equation $ax\equiv b\pmod{n}$ that it has a unique solution (mod n) when gcd$(a,n)=1$? –  Jul 04 '11 at 04:03
  • @Bill: Hmm, Bezout's identity is more natural to find the inverse. I was thinking about the solution of the congruence equation $ax\equiv 1\pmod{n}$, which finally reduces to the issue of the identity you mentioned:) –  Jul 04 '11 at 04:13
  • @Jack. Indeed. Note that Chandru's final sentence is the same as the hint I gave to your prior question. – Bill Dubuque Jul 04 '11 at 05:31
