I was reading this answer to the question of the division by zero which proposes the idea of "warped" numbers.
So, am I correct, the following rules could be a definition of division by zero:
Let:
- $\infty_w$ be a type of infinity with the properties below.
- $Q+$ be the set of rational numbers and $\infty_w$
- $x$ be any element of $Q+$
(1) $\frac{x}{0} = x\times\frac{1}{0}$
(2) $\frac{1}{0} = \infty_w$
(3) $x + \infty_w = \infty_w$
(4) $x$ if nonzero: $x \times \infty_w = \infty_w$
(5) $0 \times \infty_w = 0$
(6) $\frac{1}{\frac{1}{0}} = 0$
The problem is that there is no gain from such a logic. Division by zero would only be interesting if there was some nontrivial theorem that could be attained from such a logic?
Did I get this right or is the above example different from "warped" numbers presented in the previous answer? Or are there more contradictions that arise from the example above?
My main point is understanding the strange logic that is required for division by zero to be logically consistent and how these assumptions would need to break basic assumptions about rational numbers. Is my example above logically valid?
