The domain of consideration is the set of whole numbers, $\mathbb{N}_0$.
The following theorem (see facsimile below) appears in The Number System, by H.A. Thurston:
3. Theorem: There is just one operation $\theta$ such that, for every $x$ and $y,$ \begin{align*} (i)\text{ }\theta\left(x,0\right)=&x\text{ and}\\ (ii)\text{ }\theta\left(x,y^{\prime}\right)=&\theta\left(x,y\right)^{\prime}. \end{align*} Proof: If $\theta$ exists, let $\phi$ be an operation such that \begin{align*} (iii)\text{ }\phi\left(x,0\right)=&x\text{ for every }x\text{ and}\\ (iv)\text{ } \phi\left(x,y^{\prime}\right)=&\phi\left(x,y\right)^{\prime}\text{ for every }x\text{ and }y. \end{align*} Let $M$ be the set of $y$ for which $\phi\left(x,y\right)=\theta\left(x,y\right)$ for every $x.$ Then $0\in M,$ because $\phi\left(x,0\right)=x=\theta\left(x,0\right)$ for every $x,$ by $(iii)$ and $(i).$ \begin{align*} \text{If }y\in M\text{, then }\phi\left(x,y^{\prime}\right)= & \phi\left(x,y\right)^{\prime}\text{ by }(iv)\\ = & \theta\left(x,y\right)^{\prime}\text{ because }y\in M\\ = & \theta\left(x,y^{\prime}\right)\text{ by }(ii). \end{align*} Therefore $y^{\prime}\in M.$ Therefore, by [the principle of induction], $M$ contains all whole numbers, and so $\phi\left(x,y\right)=\theta\left(x,y\right)$ for every $x$ and $y;$ that is, there is at most one operation satisfying $(i)$ and $(ii).$ It remains to prove that there is at least one. Let $M$ be the set of $x$ for which there is, for each $y,$ a whole number $\theta\left(x,y\right)$ such that $(i)$ and $(ii)$ are true. If we let \begin{align*} (v)\text{ }\theta\left(0,y\right)= & y\text{ for every }y,\text{then}\\ \theta\left(0,0\right)= & 0\text{ by }(v). \end{align*} Therefore $(i)$ is true when $x=0.$ And \begin{align*} \theta\left(0,y^{\prime}\right)= & y^{\prime}\text{ by }(v)\\ = & \theta\left(0,y\right)^{\prime}\text{ by }(v). \end{align*} Therefore $(ii)$ is true when $x=0.$ Therefore $0\in M.$ If $z\in M,$let \begin{align*} (vi)\text{ }\theta\left(z^{\prime},y\right)= & \theta\left(z,y\right)^{\prime}\text{ for every }y. \end{align*} ($\theta\left(x,y\right)$ is defined, because $z\in M.$) Then \begin{align*} \theta\left(z^{\prime},0\right)= & \theta\left(z,0\right)^{\prime}\text{ by }(vi)\\ = & z^{\prime}\text{ by }(i) \end{align*} because $z\in M.$ Therefore $(i)$ is true when $x=z^{\prime}.$ And \begin{align*} \theta\left(z^{\prime},y^{\prime}\right)= & \theta\left(z,y^{\prime}\right)^{\prime}\text{ by }(vi)\\ = & \theta\left(z,y\right)^{\prime\prime}\text{ by }(ii)\text{ because }z\in M\\ = & \theta\left(z^{\prime},y\right)^{\prime}\text{ by }(vi). \end{align*} Therefore $(ii)$ is true when $x=z^{\prime},$ and so $z^{\prime}\in M.$ Therefore, by [the principal of induction], $M$ contains every whole number, and so $(i)$ and $(ii)$ are true for every $x$ and $y.$
I contend that to prove the existence of $\theta$ it suffices to show that for arbitrary $x\in\mathbb{N}_0$ the function $\alpha_x\left(y\right)=\theta\left(x,y\right)$ satisfying $(i)$ and $(ii)$ is well defined. So, for all $x,y\in\mathbb{N}_0$ we define \begin{align*} \alpha_x\left(y\right)\in&\mathbb{N}_0,\\ \alpha_x\left(0\right)=&x,\\ \alpha_x\left(y^{\prime}\right)=&\alpha_x\left(y\right)^{\prime}.\\ \end{align*}
The only condition on $x$ is that it is a whole number. So $\alpha_x$ is defined for $x=0$ and since $x\in\mathbb{N}_0$ then $x^\prime\in\mathbb{N}_0.$ So $\alpha_{x^\prime}$ is equally well defined. Similarly,since $y,\alpha_x\left(y\right)\in\mathbb{N}_0$ then $y^\prime,\alpha_x\left(y\right)^\prime\in\mathbb{N}_0.$
Is this sufficient to prove the existence of $\theta$ as defined in Thurston's theorem quoted above?
  • I don't understand all these usages of prime. Are $x,y$ both function of let say $t$ and the ' is to be understood as $\frac{d}{dt}$ ? Is $n$ an integer (you speeak about induction) but then proceed to derive it, is it $n(t)$ and arbitrary function then, and the induction is on the iterated derivatives ? Also I don't understand $x=\theta(x,0)=\theta(x,0')=\theta(x,0)'=x'$ what about $x$ is not an exponential ?! A lot of confusion for me on your post. – zwim Feb 20 '24 at 13:41
  • This is the recursive definition of addition $,a_x(y) = x+y,,$ where $,n' = n+1,,$ viz.
    $$\begin{align} a_x(0) &= x\ a_x(y+1) &= a_x(y)+1\end{align}\qquad$$
    Existence and uniqueness of $,a_x(y),$ follows from general results about recursive (inductive) definitions.
    – Bill Dubuque Feb 20 '24 at 13:44
  • Re: "pedantic overkill" - see the award winning Monthly paper by Leon Henkin cited here for an excellent introduction to induction and inductive definitions - which makes clear why such rigor is necessary. – Bill Dubuque Feb 20 '24 at 13:50
  • Sorry. I forget that not everybody is familiar with successor notation. $x^\prime=x+1$ except we don't know what plus and $1$ are yet. – Steven Thomas Hatton Feb 20 '24 at 13:51
  • @BillDubuque If something is defined for all $x$ proving it inductively seems a bit superfluous. As far as I know, I'm the person who introduced the subscript notation you are using. – Steven Thomas Hatton Feb 20 '24 at 13:57
  • "Intuitively obvious" is not "rigorous proof". One could also claim that the construction of $\Bbb N$ is obvious, as is the existence and uniqueness of recursively defined functions on $\Bbb N,\ldots $ as is unique prime factorization, etc. But all of those claims require justification, i.e. rigorous mathematical proof. Lacking such proof you are performing magic, not mathematics. – Bill Dubuque Feb 20 '24 at 14:23
  • @BillDubuque My question is not whether the given steps are excessive. My question is whether they are sufficient. – Steven Thomas Hatton Feb 20 '24 at 21:28
  • @StevenThomasHatton It seems to me you prove that one such function exists (by exhibiting it), not that there is exactly one such function as per Thurston's theorem. – Julio Di Egidio Feb 21 '24 at 13:07
  • @JulioDiEgidio I should have made clear that I am accepting his proof of uniqueness. I just find his proof of existence to be overly arcane. I think he did it that way to use the steps in the future. Perhaps I should study his proof more carefully before criticizing it too harshly. – Steven Thomas Hatton Feb 21 '24 at 13:23
  • @BillDubuque I contend that the statement of the theorem is the statement of its proof by induction on $y$. (i) provides the base case. (ii) provides the induction step with the assumption that $\theta(x,y)\in\mathbb{N}_0.$ Since the only condition on $x$ is that it is a whole number, there is nothing further to say about $x$. – Steven Thomas Hatton Feb 23 '24 at 19:28
I reject Thurston's entire proof, including the uniqueness part. Changing the name of the operator proves nothing. His proposed proof of existence shows that $(v),(vi)$ provide equivalent definitions of $\theta.$ That begs the question.
Instead I proceed as follows: $\theta$ can be viewed as a three-place relation of whole numbers. Thus it can be treated as the set
$$\vartheta=\left\{\langle{x,y,z}\rangle\backepsilon z=\theta\left(x,y\right)\right\}\subset\mathbb{N}_0^3$$
generated recursively using $(i),(ii).$ That $\vartheta\neq\mathbb{N}_0^3$ follows from $\langle{0^\prime,0,0}\rangle\notin\vartheta.$
To show that this generation deterministically produces exactly $\vartheta,$ we could use induction on $x$ with each step being induction on $y.$ However, since $(i),(ii)$ are defined identically for all $x,$ there is no need for induction on $x$. Thus we consider the case of an arbitrarily chosen $x.$
Assume $x\in\mathbb{N}_0.$ Rule $(i)$ provides the base case. Assume $y=0.$
$$(i)\land y=0\implies\langle x,y,x\rangle\in\vartheta$$
So $\theta$ is uniquely determined for each $x$ and $y=0.$
Rule $(ii)$ provides the $y\mapsto y^\prime$ induction step. For arbitrary $y\in\mathbb{N}_0$ assume $z=\theta\left(x,y\right)\in\mathbb{N}_0$ is uniquely determined.
$$(ii)\land\langle x,y,z\rangle\in\vartheta\implies\langle x,y^\prime,z^\prime\rangle\in\vartheta$$
Uniqueness and closure follow from the defined uniqueness and closure of the successor of a whole number.
Thus we have shown that for all $x$ we have that $\theta\left(x,y\right)\in\mathbb{N}_0$ is uniquely determined for $y=0,$ and if $\theta\left(x,y\right)\in\mathbb{N}_0$ is uniquely determined for $y\in\mathbb{N}_0$ then $\theta\left(x,y^\prime\right)\in\mathbb{N}_0$ is uniquely determined.
We conclude that $\theta:\mathbb{N}_0\times\mathbb{N}_0\mapsto\mathbb{N}_0$ is well defined. That is, $\theta$ gives exactly one whole number for each pair of whole number arguments.
To regain Thurston's implicit results that $\theta\left(0,y\right)=y$ and $\theta\left(x^\prime,y\right)=\theta\left(x,y^\prime\right)$ we proceed as follows:
By $(i)$ we have $y=0\implies\theta\left(0,y\right)=y=0.$
By $(ii)$ and the induction hypothesis that for arbitrary $y$ we assume $\theta\left(0,y\right)=y$ we obtain $\theta\left(0,y^\prime\right)=y^\prime.$
So we have produced Thurston's $(v)$
$$y\in\mathbb{N}_0\implies\theta\left(0,y\right)=y.$$
We now show $$\theta\left(x^\prime,y\right)=\theta\left(x,y^\prime\right).$$
Assume $x$ is arbitrary and $y=0.$ By $(i)$ we have the first two equalities in $$y=0\implies\theta\left(x^\prime,y\right) =x^\prime=\theta\left(x,y\right)^\prime =\theta\left(x,y^\prime\right).$$ The third equality follows from $(ii).$
Assume that for arbitrary $x,y$ we have $$\theta\left(x^\prime,y\right)=\theta\left(x,y^\prime\right).$$
The induction step $y\mapsto y^\prime$ is as follows: Using $(ii)$ to obtain the first and third equalities, and our assumption to obtain the second, we have $$\theta\left(x^\prime,y^\prime\right) =\theta\left(x^\prime,y\right)^\prime =\theta\left(x,y^\prime\right)^\prime =\theta\left(x,y^{\prime\prime}\right).$$
Using $(ii)$ we recover Thurston's $(vi)$
$$\theta\left(x^\prime,y\right)=\theta\left(x,y\right)^\prime.$$
