The question is:
Let $n > 1$ be a positive integer. Show that
${1}+{1/2}+1/3 \ldots+1/n$
is not an integer. (Try not to use any powerful results about the distribution of prime numbers)
My attempts:
suppose the $n+1$ th sum is an integer, $k$
$k = 1 + \frac{1}{2} \ldots + \frac{1}{n+1}$
Then the $n$ th sum
$S_{n} = k - \frac{1}{n+1} = \frac{kn+k-1}{n+1}$
The $n$ th sum can also be expressed as
$S_{n} = \frac{a}{n!}$ with some integer $a$
Therefore,
$\frac{a}{n!} = \frac{kn+k-1}{n+1}$
$a = \frac{(n!)(kn+k-1)}{n+1}$
$kn+k-1$ and $n+1$ are coprime so for $a$ to be an integer we need $n+1|n!$
This is where I got stuck. From this I saw that it is then impossible for $n$ to be one less than a prime but from here I don't understand where to go. There are examples of both $n+1$ dividing $n!$ (eg: $n=5$) and of not dividing $n!$.
