I am trying to follow a derivation in a paper. The reason it is of importance is because I want to make a slight change to one of the equations. But in order to do that, I need to understand how they were able to arrive at the original final result. Here are the three equations:
$$\frac{hr}{R^2} = \frac{q^2}{R^2}\sin\beta$$
$$\left(\frac{q}{R}sin\phi\right)^2 + \left(\frac{q}{R}cos\phi - \frac{b}{R}\right)^2sin^2\beta = 1$$
q is a variable length and $\phi$ is a variable angle. R is a constant. The angle, $\beta$, is a constant in this equation as well.
The third equation is:
$$\frac{b}{R} = \cot\beta$$
So since the angle $\beta$ is a constant that means that $\frac{b}{R}$ is also a constant.
The authors claim that they combined these three equations to come up with the final result which is,
$$\frac{hr}{R^2} = \frac{\sin^3\beta}{(1-\cos\phi\cos\beta)^2}$$
Right now Eq. 2 is what is giving me problems. I can't see anyway of solving it for $\frac{q^2}{R^2}$ so that I can plug the result into the first equation. If I multiply out the quadratic in Eqn 2, it leaves me with a term that includes $\frac{2qb}{R^2}$. Because of that term, I can't see how to ultimately solve for $\frac{q^2}{R^2}$.
Edit: Below is the diagram that applies to the 2nd equation. Again, the angle $\beta$ is a constant for this scenario even though it is not shown in the drawing. O is the origin and P is a focus of the ellipse.
