If $S_i$ represents the number of books on the $i$th shelf then the problem can be rewritten as: $k = \sum_{i=1}^n S_i$ where $S_i \le m \iff x_i = m - S_i \ge 0$ and $S_i = m - x_i$ then $k = \sum_{i=1}^n (m - x_i) = nm - \sum_{i=1}^n x_i \implies nm - k = \sum_{i=1}^n x_i$ therefore there are ${nm - k + m - 1}\choose{m - 1}$ solutions to the equation. Then we can shuffle around the books in $k!$ ways then the final answer is $k!$${nm - k + m - 1}\choose{m - 1}$. Is this solution correct?
then what are you asking ? – Not a Salmon Fish Jan 09 '24 at 19:23
@NotaSalmonFish If it's correct or not. I forgot to add that part sorry – Marin Jan 09 '24 at 19:24
At a glance, no I don't expect this to be right. I am struggling to understand your logic however. It seems to me that rather than "putting $S_i$ books onto a shelf" you are "choosing how many holes are left on each shelf" (where each shelf has capacity $m$) and are correctly noting that you will necessarily have a non-negative number of holes. You do correctly account for no shelf having too many books in this way, however you don't seem to be correctly accounting for the fact that no shelf can have more holes than its capacity. – JMoravitz Jan 09 '24 at 19:30
1The typical approach will be inclusion-exclusion for this problem (though it does get messy to write in its most general form) or will be generating functions. – JMoravitz Jan 09 '24 at 19:31
@JMoravitz I did think of using incl/excl but i'm not sure how to construct the individual sets. – Marin Jan 09 '24 at 19:40
You consider all arrangements if there were no upperbounds to consider, then remove those for which at least one of the shelves had too many books. Expand what you remove via inclusion-exclusion noting that if for instance it was that the first two shelves both had too many books (among possibly others) then it is the case that they had at least $m+1$ books on each. Count that case like normal, but having put $m+1$ books on each ahead of time, thus needing to still distribute $k-2m-2$ books, and so on... – JMoravitz Jan 09 '24 at 19:43
2In the case of generating functions, it is easy to write the answer, less easy to compute the answer. It is going to simply be $k!$ times the coefficient of $x^k$ in the expansion of $(1+x+x^2+\dots+x^m)^n$ – JMoravitz Jan 09 '24 at 19:44
@JMoravitz Where can I learn how to use generating functions for the inclusion-exclusion principle. My class has only covered the regular version. – Marin Jan 09 '24 at 19:46
To be clear, I did not suggest combining the two. I suggested two completely different methods. Inclusion-exclusion should be covered in any introductory textbook. Generating functions on the other hand are at least touched on in most books but not necessarily in great detail. Generatingfunctionology covers them at length and does a good job of showcasing their strength for many problem types. – JMoravitz Jan 09 '24 at 19:48
@JMoravitz For your question about my logic it is as follows: Each book is represented by a 1, then $S_i$ being a sum of ones represents the number of books on that shelf. $S_i \le m$ gets transformed into an inequality with a 0 on one side so I can apply the stars and bars method. I will also check out the book you suggested, I've heard of it but haven't read it before. – Marin Jan 09 '24 at 19:50
Then yes, I understood your attempt correctly and am still of the opinion it is wrong. For evidence, consider an extreme example of $k=1$ book, $n$ a large number and $m$ a large number. There should be simply $n$ possible ways to arrange, but by your attempt you would have had a much larger number than that, bigger than $nm$ – JMoravitz Jan 09 '24 at 19:54
@JMoravitz Yes it is wrong. I wonder why it felt so correct when I was writing it..... – Marin Jan 09 '24 at 19:59
The number of ways to place $k$ distinct books on $n$ distinct shelves, such that each shelf has at most $m$ books, is $$ \sum_{i=0}^n (-1)^i \binom ni \binom{k}{(m+1)i}\cdot \big((m+1)i\big)!\cdot \frac{(n+k-(m+1)i-1)!}{(n-1)!}. $$ I will prove this using the principle of inclusion-exclusion.
First, let us answer a simpler question. Ignoring the maximum capacity of $m$, how many ways are there to place $k$ distinct books on $n$ distinct shelves? The answer is $$ n\cdot (n+1)\cdot (n+2)\cdots (n+k-1)=\frac{(n+k-1)!}{(n-1)!}\tag1 $$ You can choose a placement of books as follows. Take the $k$ distinct books, along with $n-1$ identical dividers, and arrange these $n+k-1$ items into a line in $(n+k-1)!/(n-1)!$ ways (we divide by $(n-1)!$ because the $n-1$ dividers are identical). The dividers split the books into $n$ sections, corresponding to the shelves.
Let $S$ be the set of all ways to place $k$ distinct books on $n$ distinct shelves. For each $i\in \{1,\dots,n\}$, let $E_i$ be the set of arrangements in $S$ for which the $i^\text{th}$ shelf has more than $m$ books. The arrangements in each $E_i$ are bad, so we need to count $|S\setminus (E_1\cup \dots \cup E_n)|$, which is what PIE is for. Using PIE, we have $$ \begin{align} |S\setminus (E_1\cup \dots \cup E_n)| &= \sum_{i=0}^n (-1)^i\sum_{1\le j_1<\dots <j_i\le n}|E_{j_1}\cap \dots \cap E_{j_i}| \\ &= \sum_{i=0}^n (-1)^i\binom ni|E_{1}\cap \dots \cap E_{i}| \end{align} $$ All that remains is to find $|E_{1}\cap \dots \cap E_{i}|$, which is the number of arrangements where the first $i$ shelves have too many books. There is a nice combinatorial way to do this.
First, set aside $(m+1)i$ books. There are $\binom k{(m+1)i}$ ways to do this.
Next, arrange the $(m+1)i$ books on the first $i$ shelves, with $m+1$ books per shelf. There are $\big((m+1)i\big)!$ ways.
Finally, place the remaining $k-(m+1)i$ books onto the $n$ shelves, such that the previously placed books stay at the leftmost positions on their shelves. We are back in the situation which was solved by $(1)$, except with $k-(m+1)i$ books instead of $k$, so the number of ways is $(n+k-(m+1)i-1)!/(n-1)!$.
Putting this altogether, we get the answer advertised at the beginning.
The answer can be rewritten as $$ k!\sum_{i=0}^n (-1)^i \binom ni \binom{n+k-(m+1)i-1}{k-(m+1)i} $$ This is exactly $k!$ times the number of ways to place $k$ identical books on $n$ shelves so that no shelf has more than $m$ books. Furthermore, the identical book problem is equivalent to counting integer solutions to the equation $$ x_1+\dots+x_n=k, $$ where the variables must satisfy $0\le x_i\le m$ ($x_i$ is the number of books on the $i^\text{th}$ shelf). See Extended stars-and-bars problem(where the upper limit of the variable is bounded) for a generating function solution to the identical book/counting integer solutions problem.
- 75,930
