In a nutshell, I wish to understand this post by Ted Shiffrin, the relevant bit of which reads
For example, suppose you have a surface $S$ in $\mathbb R^3$ that you can locally write as $f=0$, but you don't know how to do so globally. You can cover $S$ with open sets $U_i\subset\mathbb R^3$ on which you have smooth functions $f_i\colon U_i\to\mathbb R$ with $S\cap U_i = \{x\in U_i: f_i(x)=0\}$. Consider $\Phi = \{\phi_i\}$, where $\phi_i$ is supported in $U_i$. Then $f=\sum \phi_if_i$ will define a smooth function with $f=0$ on $S$. If you want $f$ to be zero only on $S$, you can take an additional open sets $U_0 = \mathbb R^3 - S$, set $f_0 = 1$, and throw $\phi_0f_0$ into your sum.
Formally, what does the bold statement mean?
