I am a undergradute math student and I was traying to prove the polynomial $p(x)= x^4-10x^2+1$ is irreducible in $\mathbb{Q}[x]$. I used reduction mod p and for every prime p I found a factorizarion in $\mathbb{Q}[x]$. I know $p(x)$ is irreducible, but i have a question about this method. If I try with many primes and anyone works, i have to try until I find one that works? or try with another method.Thanks for any comments.
Asked
Active
Viewed 53 times
No, it never works for any prime here with the reduction criterion, but it is well known that the polynomial is irreducible over $\Bbb Q$. See this duplicate and this one. – Dietrich Burde Dec 13 '23 at 19:25
Yes, but i have another question. If i have a polynomial p(x) and I try with reduction mod p, and if i try with p=2, and does not work, the i try with p=3, and does not work again, it could be posible that it works for p = 53, for example? Or, if with p=2,3 does not work, is recommendable try with other primes or just change the method? – Benjamín Garcés Dec 14 '23 at 01:10
Yes, this can happen. We have many posts here as examples. See, say, this one. The polynomial is reducible modulo $p$ for $p=2,3,5,7$, but then irreducible for $p=11$. – Dietrich Burde Dec 14 '23 at 09:27
