Consider $\int e^x \mathrm{d}x$. Using integration by parts, and setting $u=e^x$, $v=1$, we find that $\int e^x \mathrm{d}x = xe^x-\int \frac 1 2 x^2 e^x \mathrm{d}x = xe^x - \frac 1 2 x^2 e^x + \int \frac 1 6 x^3 e^x \mathrm{d}x = \sum_{n=0}^{\infty} (-1)^n \frac {x^{n+1}e^x} {(n+1)!} + C$. Simplifying, we get $\int e^x \mathrm{d}x = e^x+C_1 = \sum_{n=0}^{\infty} (-1)^n \frac {x^{n+1}e^x} {(n+1)!} + C_2$. But $\sum_{n=0}^{\infty} (-1)^n \frac {x^{n+1}e^x} {(n+1)!} = e^x - 1$, which makes the statement above be correct iff $C_2 = C_1 + 1$. However, I thought that integration by parts always yielded statements where the constants were the same on both sides of the equation. Why is this occurring?
Asked
Active
Viewed 152 times
9don't forget "$+C$"... You could also try your formal calculation as a definite integral: $\int_0^x e^t,dt$. – peter a g Oct 10 '23 at 00:32
@peterag Make this an answer. – GEdgar Oct 10 '23 at 00:48
Indefinite integrals are always computed up to an additive constant. – Abezhiko Oct 10 '23 at 04:17
1This is addressed in this answer to a previous question. – JonathanZ Oct 10 '23 at 05:27
As requested:
Don't forget the "+C" of indefinite integration. You could also try your formal calculation in the form of a definite integral: $$ \int^x_0 e^t\,dt.$$
peter a g
- 4,923
