Let $X$ be a Cauchy distribution with parameter $\theta$, that is to say, its density function is:
f(x;\theta) = \frac{\theta}{\pi(x^2 + \theta^2)}
I'm asked to get the distribution of $Y$ where $Y = X \bmod 2\pi$. I've tackled this problem but I feel like I'm stuck. My attempt so far has been the following: Let's compute the distribution function for $Y$:
F(y) = P(-\pi \leq Y \leq y) = P(\bigcup_{n=-\infty}^{\infty} \{ -\pi + 2\pi n \leq X \leq y + 2\pi n \} )
Integrating $X$'s density function I reach the following series:
F(y) = \sum_{n = -\infty}^{\infty} \int_{-\pi + 2\pi n}^{y + 2\pi n} \frac{\theta}{\pi (x^2 + \theta^2)} = \sum_{n = -\infty}^{\infty} \frac{1}{\pi}\left[ \arctan{\frac{2\pi n + y}{\theta}} - \arctan{\frac{2\pi(n-1)}{\theta}} \right]
I can now differentiate to get the density function of $Y$:
f(y) = \sum_{n=-\infty}^{\infty} \frac{1}{\pi}\frac{1}{1+\left(\frac{2\pi n + y}{\theta} \right)^2}
However, my professor has told me that he expects a closed form solution. In order to do that he has told me that I should use the Poisson kernel, but I'm not exactly sure how should I proceed with that information. I've tried using the logarithmic expression for the inverse tangent to no avail. I've noticed that the density function of $X$ IS the Poisson kernel for the upper half-plane, but I'm not entirely how that could help. I've tried expressing either of the two series I've provided in a form that allows to apply the Poisson kernel summation formula (the one for the circle) but I haven't had success with that approach. If you could help me in any way I would really appreciate it. Finally, I know it is a trope but I have to say: English is not my mother tongue, so I'm sorry if there are any typos. Thanks for your attention.
Edit: I wish I could accept both answers because they are helpful in different ways, but the system is what it is. Thank you both for your thorought responses!
1This result may be of interest https://math.stackexchange.com/questions/736860/find-the-infinite-sum-of-the-series-sum-n-1-infty-frac1n2-1 – Albert Paradek Sep 28 '23 at 09:25
It seems like I could evaluate the density series using that technique. I'll take a look later, thank you so much. – Raúl Blázquez Bullón Sep 28 '23 at 10:52
3This is called a Wrapped Cauchy distribution. – StubbornAtom Sep 28 '23 at 18:16
The probability is simply $$\sum_{n=-\infty}^{\infty}f(x+2\pi n;\theta) = \frac\theta\pi\sum_{n=-\infty}^{\infty}\frac{1}{(x+2\pi n)^2 + \theta^2}$$ We can use the Poisson summation formula, but first we need to compute the Fourier Transform $$\frac1{(2\pi t)^2+\theta^2}\longleftrightarrow\frac{e^{-\theta|f|}}{2\theta}$$ $$\frac1{(2\pi t+x)^2+\theta^2}\longleftrightarrow\frac{e^{-\theta|f|-ifx}}{2\theta}$$ Therefore, $$\sum_{n=-\infty}^{\infty}\frac{1}{(x+2\pi n)^2 + \theta^2}=\sum_{n=-\infty}^{\infty}f(n)=\sum_{n=-\infty}^{\infty}\hat f(n)\\=\frac{1}{2\theta}\sum_{n=-\infty}^{\infty}e^{-\theta|n|-inx}=\frac{\sinh\theta}{2\theta(\cosh\theta-\cos x)}$$ Finally, $$\sum_{n=-\infty}^{\infty}f(x+2\pi n;\theta) =\frac{\sinh\theta}{2\pi(\cosh\theta-\cos x)},0\le x\le2\pi$$
- 3,148
The Poisson kernel (See Rudin , Real and complex analysis, page 223) is for $0<r<1$ $$P_r(x)=\sum_{n\in Z}r^{|n|}e^{inx}=\frac{1-r^2}{1-2r\cos x +r^2}$$ and therefore $$r^{-|n|}=\frac{1}{2\pi}\int_0^{2\pi} e^{-inx}P_r(x)dx.\ (*)$$ The Fourier transform of the Cauchy variable $X$ estimated on the integer $n$ is $$e^{-\theta|n|}=\frac{1}{\pi}\int_{R}\frac{\theta}{\theta^2+x^2}e^{inx}dx=\frac{1}{\pi}\sum_{n\in Z}\int_{0}^{2\pi}\frac{\theta}{\theta^2+(x-2\pi n)^2}e^{in x}\ \ (**)$$ Comparing (*) and (**) the density of $X$ modulo $2\pi$ is $\frac{1}{2\pi}P_{e^{-\theta}}(x)$ since these two functions have the same Fourier coefficients.
- 4,357
