The task is to calculate what we get when we plug $x_{0}=\left( \frac{\pi}{2} \right)$ into the derivative of the function: $$f\left( x \right)=2^{\ln\tan^{2}\left( x-\frac{\pi}{4} \right)}$$ (We also have to calculate the derivative ourselves). When I derived the function I got:$$f'\left( x \right)= \frac{2^{\ln\tan^{2}\left( x-\frac{\pi}{4} \right)+1}\cdot\ln2}{\tan\left( x-\frac{\pi}{4} \right)\cdot\cos^{2}\left(x-\frac{\pi}{4} \right)}$$Upon plugging in $x_0$, I got: $$f'\left( \frac{\pi}{2} \right)=4\cdot\ln2$$This is what the teacher, what multiple people I asked, and what I myself got as the answer. However, when I tried first plugging in $x_0$ into f(x), and then deriving the result, this is what I got: $$f\left( \frac{\pi}{2} \right)=1$$ And as you know, 1 derived is equal to zero. Why don't the solutions match?
When you take the derivative of a function, you take it with respect to a variable - in early calculus classes, this is typically $x$. For this to work, you need the function to depend on that variable. By substituting before differentiating, you are removing the thing that you are trying to differentiate by. This leaves you with a constant function, and the derivative of a constant is always zero, which is clearly not going to be correct.
ConMan
  • 24,300
