Given $p_1,p_2,p_3 \in S^2 = \{x \in \mathbb{R}^3 \mid \lVert x \rVert = 1\}$ all distinct, I wish to prove that \begin{align*} J &:=(p_1p_2 - 1)^2 + (p_1p_3 - 1)^2 + (p_2p_3 - 1)^2\\ &\qquad - (p_1p_2 - p_1p_3)^2 - (p_1p_3 - p_2p_3)^2 - (p_2p_3 - p_1p_2)^2\\ &> 0 \end{align*} where $p_ip_j := p_i\cdot p_j$ denotes (for better readability and to save space) the regular dot product in $\mathbb{R}^3$.
$p_i \in S^2$ implies $p_ip_j \in [-1, 1)$. I can make $J \to 0^+$ by choosing $p_1 = -p_2$ and having $p_3 \to p_1$, so that $p_1p_2 = -1$, $p_1p_3 \to 1$, $p_2p_3 \to -1$. $J$ then approaches $(-2)^2+0^2+(-2)^2-(-2)^2-2^2-0^2=0$. If each $p_ip_j$ were allowed to be chosen freely in that range, $J$ can become negative, e.g. by choosing $p_1p_2=-1, p_1p_3=0, p_2p_3=0.9$. Then $J=-0.41<0$.
I believe the interrelatedness between the $p_i$’s make the inequality $J>0$ hold, but at the same time haven’t been able to show that no combination of $p_i$’s can produce e.g. those values of $p_ip_j$ that fail. (I believe $J=0$ is only possible by allowing $p_i = p_j$, but haven’t checked this.)
I tried bounding $p_1p_3$ after fixing the other two (e.g. if they were all in the $x-y$ plane, $\theta_{ij}$ are related, and $p_ip_j=\cos\theta_{ij}$) but didn’t get very far even with that simplification.
For some context in case it turns out to be useful, or just as an aside: $J$ is one of several discriminants used to classify quadratic curves. Let the plane passing through $p_1, p_2, p_3$ be $H = \{p_1 + s(p_2-p_1) + t(p_3-p_1) \mid s,t \in \mathbb{R}\}$. My $J$ arises from the intersection of $S^2$ with $H$, which is well known to be a circle in real space $\mathbb{R}^3$. Proving $J > 0$ shows that the corresponding solution curve for $(s,t)$ in the $s-t$ plane "configuration space" is an ellipse, which can also be easily seen to pass through $(s,t) = (0,0), (1,0), (0,1)$.
