I try to find a solution to this partial differential equation (in a thermodynamic problem again):
$$ \left[ \partial_x^2 + a(t) \partial_x - \partial_t \right] w(x,t) = 0 $$
Where $a$ and $w$ are real valued functions, $x > 0$ and $t > 0$ position and time. Do we have general solution for arbitrary $a(t)$ ?
HINT/TRACK
Related to this topic, when we remind that for this simple equation:
$$ \left( \partial_x + \frac{1}{c} \partial_t \right) f(x,t) = 0$$
The general solution is (using the shift operator and an arbitrary function $h(t)$):
$$ f(x,t) = e^{- \frac{x}{c} \partial_t } h(t) = h(t-x/c) $$
So my idea was to use also shift operator $e^{\partial_t}$. So I pose:
$$ w = e^{x \hat{s}(t)} D(t) $$
where $\hat{s}(t)$ is an operator on $t$, $D(t)$ function of $t$. Then I replace in the equation and obtained:
$$ ( \hat{s}^2 + a \hat{s} - \partial_t ) D(t) = 0 $$
I solve the quadratic operator equation on $\hat{s}(t)$ and obtained:
$$ \hat{s}_{1,2} = - \frac{a}{2} \pm \frac{1}{2} \sqrt{a^2 + 4 \partial_t} = - \frac{a}{2} \pm \hat{k} $$
with $\hat{k} = 1/2 \sqrt{a^2 + 4 \partial_t} $. Where I suppose I can evaluate the square root of the operator by applying an expansion as for the shift operator.
Now here comes the problem: $a(t)$ and $\hat{k}(t)$ does not always commute (only if $a$ is a constant). So the 2 independent solutions are somehow difficult to express, intuitively we should think to (for example):
$$ w(x,t) = e^{- x \frac{a}{2}} e^{x \hat{k} } D_1(t) + e^{- x \frac{a}{2}} e^{- x \hat{k} } D_2(t) = w_1(x,t) + w_2(x,t) $$
So from here things begin to get tricky since we are dealing with operators and Poisson's Bracket, because for example for $w_1$ we obtain:
$$ \left[ \partial_x^2 + a(t) \partial_x + \partial_t \right] w_1(x,t) = \left[\frac{a(t)}{2},\hat{k} \right] w_1(x,t) \neq 0 $$
Do you have an idea for this track (maybe Lie algebra or stuff like that?)?
Thanks for reading
