How do you simulate a 10 sided die using a 6 sided die.
I came across this question in my Probability textbook
My 2 approaches:
E[x] of 10 sided die = 5.5, E[x] of 6 sided die = 3.5
1st Method:
Roll the 6 sided twice. Now on the 3rd roll keep rolling until you get a (1,2,3,4,5) and reject/reroll a 6. Now divide the result of the 3rd roll by 2 and subtract from the sum of the 1st 2 rolls.
E[x] = 3.5 + 3.5 - (3/2) = 5.5
2nd Method:
Roll the 6 sided die. Now for the 2nd roll keep rolling until you get a (1,2, or 3) i.e. reject/reroll on (4,5, or 6).
E[x] = 3.5 + 2 = 5.5
I realize that the 1st method is probably better in terms of fewer rolls required on average
I am wondering if there is some other more optimal solution that reduces the average number of rolls required. Thanks!
    Matching expectation is not the same as matching the distribution. We could just have the constant distribution $5.5$ That clearly matches expectation. – lulu Aug 04 '23 at 11:31
    Slightly more elaborate: you could toss the $d6$ repeatedly and make a "decimal" in base $6$ out of the rolls. Then if your decimal is between $\frac {i-1}{10}$ and $\frac i{10}$ you call that a roll of $i$ on the $d10$. Of course, you might get exactly $\frac i{10}$ for some $i$ in which case this is undetermined, but that's probability $0$. – lulu Aug 04 '23 at 11:36
  • Make $2$ rolls of a 6-sided die, $r_{1}$ and $r_{2}$. Compute $[\frac{6 r_{1} + r_{2}-4}{3}]$ . If it is no greater than $10$, then it perfectly simulates a single $10$ die roll. The probability of this being true is $\frac{5}{6}$ – user3257842 Aug 04 '23 at 11:48
  • There was a typo in my prior comment so I deleted it. A better version of it: toss the $d6$ three times and keep track of the ordered triple of outcomes. There are $216$ equally likely ordered triples, so partition them into ten groups of $21$ with six left over. Then identify each group with one of the faces on the $d10$. That works unless you get one of the excess six, in which case just try again. the probability of a "failure" of this method is $\frac 6{216}=\frac 1{36}$ so in practice a few tries will get you a good result. – lulu Aug 04 '23 at 11:49
    As an aside, it should be emphasized that whatever method you use here will necessarily require a potentially unbounded number of attempts to resolve. This is a result of the simple fact that $10$, your target, has a prime factor of $5$ which is not present in $6$, the type of die you are rolling. For instance, in @hdci's approach below (which is perfectly reasonable in practice) you could theoretically roll a result of 6 a thousand times in a row and still not have determined what your d10 result should have been, needing to continue throwing the d6 even more. – JMoravitz Aug 04 '23 at 12:09
  • General resource https://en.wikipedia.org/wiki/Rejection_sampling – qwr Aug 05 '23 at 02:42
  • @JMoravitz it should also be noted the chance of that is exponentially small. After some point you're more likely to find a hash collision or die of a freak accident than continue rolling 6s. – qwr Aug 05 '23 at 02:47
Roll a die until its result is not six. Denote this result to be $r_1$. We have $1\leq r_1 \leq 5$.
Roll it 1 more time. Denote this to be $r_2$. We have $1\leq r_2 \leq 6$.
Compute $r_{3} = 2r_{1} - (r_2 \bmod 2)$ . This simulates a single roll of a $10$-sided die.
Now to compute the expected number of rolls.
First the expected rolls to get a non-$6$ value:
$E = \frac{5}{6} + \frac{1}{6}(E+1)$
Ie. we have $\frac{5}{6}$ chance of getting it the first try and $\frac{1}{6}$ chance of needing to try again. This gives $E = \frac{6}{5}$. The total number of rolls on average should be $1 + E = 2.2$ .
This is good if you need a single result. In limit as $n$ goes to infinity, $n$ rolls of a $10$- sided die may be simulated by $\log_{6}(10) * n$ rolls of a $6$-sided die.
user3257842
  • 3,617
We need a uniform distribution.
Suppose we only consider the outcomes: $$(1,1)\ (1,2)\ (1,3)\ (1,4)\ (1,5)\\(2,1)\ (2,2)\ (2,3)\ (2,4)\ (2,5)$$
Then there are ten outcomes and each one is equally likely to occur. There are two adjustments we must make: one, we must ignore sixes and two, it would be very tedious to roll until either a one or a two came up so we can use odd numbers on the first roll to represent a one and even rolls to represent a two.
Note that on the first roll we cannot ignore a six because we want either even or odd.
Therefore, we roll the die twice. If the first roll is odd we write down a $1$ and if the first roll is even we write down a $2$. On the second roll we count every thing except $6$. Then the first row above represents $1$ through $5$ and the second row represents $6$ through $10$.
John Douma
  • 11,426
  • 23
  • 24
You must be sure that the probability of each integer between 1 and 10 is exactly 1/10. A safe way to do so : roll the die a first time :
  1. If you get 1, 2, 3, then roll the die as many times as required, until you get 1, 2, 3, 4 or 5 (ignoring any "6"). Thus, the probability of getting each integer between 1 and 5, knowing that the very first roll got 1, 2 or 3, is exactly 1/5
  2. Else roll the die as many times as required as previously, ignoring any "6", and add 5 to the result. Thus, the probability of getting each integer between 6 and 10, knowing that the very first roll got 4, 5 or 6, is exactly 1/5
Hence, the probability of each integer between 1 and 10 is exactly 1/10 (easy to find using the conditional probability formula).
hdci
  • 316
