I am told that the “for some” and “for some arbitrary” are different.
For example, when proving the statement “if n is odd, then $n^2$ is odd”, one of the steps includes writing $$\text{$n = 2k+1,\:\:$ where $k$ is some integer}.$$ I am told that writing “$k$ is some arbitrary integer” here is wrong?
On the other hand, in mathematical induction, when performing the inductive step, before writing the inductive hypothesis for $k,$ we write “for some arbitrary $k\text”$. I am then told that the “arbitrary” here is compulsory to write.
To me, they sound the same. Am I wrong? Are they different in terms of notation?
PS I’m relatively new to this stuff, maybe explain less using notation and appeal more to logical understanding.
ryang
  • 38,879
  • 81
  • 179
bluesky
  • 103
    Essentially, "$P$ is true for arbitrary $k$" means that it's true for all $k$. "$P$ is true for some $k$" means that there exists a $k$ for which it's true. For example, for a given $n$, it's certainly not true that $n = 2k+1$ for all $k$; there simply exists a $k$ for which it is true. However, if we write "$k^2$ for arbitrary $k$ can be written as the sum of the first $k$ odd numbers," that's true for all (positive) $k$. – Brian Tung Jul 18 '23 at 03:25
  • Writing "for some arbitrary k" is fine both cases you described. – RyRy the Fly Guy Jul 18 '23 at 04:09
In your first example, I would just write “where $k$ is an integer”. But “some” is okay. The point is, since $n$ is already known, $k$ is completely determined. Writing “where $k$ is some arbitrary integer” implies, or at least suggests, that $k$ can be any integer.
In an inductive proof on the other hand, we do mean that $k$ can be any positive integer. Writing “for some arbitrary positive integer $k$, $P(k)$ implies $P(k+1)$” means the same as “for all positive integers $k$, $P(k)$ implies $P(k+1)$.”
    This comment isn't a full answer, especially since OP prefers a notation-light response: but it might be worth noting that this is essentially the difference between the formal notations ∃ (the first case: this is true for “some” $k$) and ∀ (the second case: this is true for “all”, or for “arbitrary” $k$). – Aant Jul 18 '23 at 17:16
    Agree. In the first example, I would say $n$ is an arbitrary odd integer. But $k$ depends on $n$ so it's not arbitrary. – Matthew Leingang Jul 18 '23 at 19:53
In proofs like those you're describing, the purpose of singling out "some $k$" having "such and such property" is to prove something about all other numbers having the same property of $k$. For this reason, you can describe $k$ as arbitrary, although it is not strictly necessary. I have seen both covnentions used. What people typically mean by "for some $k$" or "for some arbitrary $k$" is "here is a particular number $k$ that is not uniquely different from any other number having the same properties."
RyRy the Fly Guy
  • 5,950
  • 27
when proving the statement “if n is odd, then $n^2$ is odd”, one of the steps includes writing $$\text{$n = 2k+1,\:\:$ where $k$ is some integer}.$$ I am told that writing “$\boldsymbol k$ is some arbitrary integer” here is wrong?
The full statement, written without ambiguity, is:
  • Given an arbitrary odd integer $\boldsymbol n,$ there is some integer $\boldsymbol k$ such that $n = 2k+1.$
    (That is, $\;\forall n{\in}\{\text{odd integers}\}\:\:\exists k{\in}\mathbb Z\:\:n = 2k+1.)$
Once we have arbitrarily taken an odd integer $n$ (in other words, once we have taken any odd integer $n$), only a particular integer $k$ satisfies the given equation. Since $k$ depends on the choice of $n,\;k$ is certainly not arbitrary.
The former means existential quantification $(∃),$ whereas the latter means universal quantification $(∀).$ To avert any potential for confusion, it is better to rewrite the latter as “for an arbitrary” or “given an arbitrary” or “for each”.
When indicating universal quantification, the word “arbitrary” is actually frequently tacit; “take an integer” is typically understood to mean “take an arbitrary integer” (“for each integer”), which of course does not mean “for some integer”.
ryang
  • 38,879
  • 81
  • 179
