Why we keep continuing to write terms in partical fraction for integrals?
For example: $\int \frac{dx}{x^4.(x+4)}$ and we rewrite integrant as $\frac {1}{x^4(x+4)}=\frac{A}{x} + \frac{B}{x^2}+\frac{C}{x^3}+\frac{D}{x^4}+\frac{E}{x+4}$
My question is why it is not enough to write just $\frac{D}{x^4}$. Why we need to other terms $\frac {1}{x^4(x+4)}=\frac{A}{x} + \frac{B}{x^2}+\frac{C}{x^3}$
And also, can we use following to rewrite integrant : $\frac {1}{x^4(x+4)}=\frac{Ax^3+Bx^2+Cx+D}{x^4} +\frac{E}{x+4}$
Fuat Ray
  • 746
You ask:
Well, a partial fraction decomposition is similar to, in some sense, writing an expression as a sum of fractions - For example when we write:
$\frac{6}{9}=\frac{1}{9}\:+\frac{2}{9}\:+\frac{3}{9}$
We can't drop any of the fractions on the R.H.S, otherwise, the equality between the two sides would be lost.
In your case, unless $A,B,C,E$ have zero value, we can't drop them and just use the fraction with $D$ (assuming it is not zero), otherwise there would be no equality between the R.H.S and the L.H.S
The fact that the Algebraic expression on the L.H.S equals the Algebraic expression on the R.H.S must always be maintained, whether we are performing integration, or doing any other manipulation requiring equality to be preserved.
NoChance
  • 6,427
