I need to solve two equations:
$$ x(1-y)=0 \\ y(1-x)=0 $$
If I had one equation, ex $x(1-y)$, the solution would be $x=0$ or $y = 1$. But how do I go about solving two such equations? Are the solutions as below? $$ x = 0 \lor y=0 \\ x = 0 \lor y=1 \\ x = 1 \lor y=0 \\ x = 1 \lor y=1 $$
Both equations in the system need to be satisfied.
  • Equation 1 says: either $x=0$ or $y=1$
  • Equation 2 says: either $y=0$ or $x=1$
If you choose $x=0$ from equation 1, then you can't choose $x=1$ for equation 2. So $y=0$.
Likewise, if you choose $y=1$ from equation 1, then you can't choose $y=0$ for equation 2. So $x=1$.
If you want to do it with boolean algebra, you have: $$\begin{aligned} ((x=0) \lor (y=1)) \land ((y=0) \lor (x=1)) &= ((x=0) \land (y=0)) \lor ((x=0) \land (x=1)) \lor ((y=1) \land (y=0)) \lor ((y=1) \land (x=1)) \\&= ((x=0) \land (y=0)) \lor \text{FALSE} \lor \text{FALSE} \lor ((y=1) \land (x=1)) \\&= ((x=0) \land (y=0)) \lor ((y=1) \land (x=1)) \end{aligned}$$
There are many solutions, and you seem to have noticed how to find them. Just plug in numbers for $x$ (or $y$) that satisfy one of the equations, and solve the other :
  • If $x = 0$, then your first equation yields $0=0$, so you're left with the equation $y=0$
  • If $x = 1$, then your first equation yields $0=0$, so you're left with the equation $y=1$
Of course, if $(x,y)$ is neither $(0,0)$ nor $(1,1)$, the system doesn't have a solution.
So your set of solutions is $\lbrace (0,0), (1,1) \rbrace$.
Chris Mzz.
  • 115
Subtracting the two equations gives $y=x$.
You have already noticed that $x=0$ or $y=1$ and therefore the solutions are $x=y=0$ or $x=y=1$.
user1172706
  • 1,405
