Exercise A-47 in Milne's Fields and Galois Theory notes asks to prove that if $p$ is a prime number and $F$ is a field of characteristic zero such that every irreducible polynomial $f(X)\in F[X]$ has degree $p^n$ for some non negative integer $n$, then every polynomial equation with coefficients in $F$ is solvable by radicals.
I already solved the exercise. The key is to show that the Galois group $\mathrm{Gal}(\overline{F}/F)$ is a $p$-group, where $\overline{F}$ is the algebraic closure of $F$.
Question: For a fixed prime $p$, is there any field $F$ satisfying the given hypothesis?
For example, for $p=2$ the answer is yes: any real closed field satisfies the hypothesis. What are such examples for other primes?
Albert
  • 2,777
Hint: You can try to look at the union of the fields $\mathbb{F}_{l^n}$ inside $\overline{\mathbb{F}}_l$, for $n$ powers of $p$.
$\bf{Added:}$ for a more sophisticated example, see Iwasawa theory.
$\bf{Added:}$ Jyrki corrected me, so the above stuff has only documentary value. Now I have an idea, not sure how good it is:
Consider a field $F$ and its algebraic closure $\bar F$. The Galois group $G=\operatorname{Gal}(\bar F/F)$ is a profinite group. I think for these kind of groups we have Sylow subgroups. So let $P$ a $p$-Sylow subgroup of $G$. The subfield $K$ of $\bar F$ invariant by $P$ has absolute Galois group $\operatorname{Gal}(\bar F/K) = P$. It follows that every finite Galois extension of $K$ has degree a power of $p$.
Obs: in fact we don't need $P$ to be a Sylow pro-$p$ group, just simply a pro-$p$ group ( I vaguely understand this). But $K$ will corresponding to a Sylow will be the smallest inside $\bar F$ (up to conjugation).
orangeskid
  • 53,909
    But that is not a field of characteristic zero, which is one of the hypothesis imposed on &F$. – Albert May 11 '23 at 22:54
  • @Albert: Oh, I missed that. But we are still winning, with unramified extensions of $\mathbb{Q}_l$. – orangeskid May 12 '23 at 00:51
  • I think that in your example you want the union of fields $\Bbb{F}_{\ell^n}$, $n$ coprime to $p$ as opposed to powers of $p$. – Jyrki Lahtonen May 12 '23 at 03:59
  • @Jyrki Lahtonen: Yes, I see, you are probably very right. My example gets every irreducible of degree prime to $p$. Maybe we can even do it for a subset $P$ of primes ... Let me think a little bit...But now lifting to the p-adic field seems not so clear.. – orangeskid May 12 '23 at 04:05
    I agree that the $p$-adic idea needs a different construction. Don't know what it would be :-( – Jyrki Lahtonen May 12 '23 at 04:12
  • @The Phoenix: These look like very concrete examples and interesting as well. It would be nice if you write an answer with them :-) – orangeskid May 13 '23 at 06:56
