We are trying to figure out a formula to find how many fabric rolls can we fit in a 40HC Container.
40HC Container Dimensions:
- Measure: Millimeters
- Length: 12,032
- Width: 2,350
- Height: 2,700
Known variables:
- Width of the roll: 220cm
- Grams per meter2 of the fabric: 200grams per meter2
- Max.Weight of each roll: 30kg
- Total Lenght Requested: 10.000mt
If the grams per meter2 of the fabric is of 200gr and the total requested amount of fabric is of 10.000mt then we will have 2000kg of fabric. And if the maximum weight a roll can have is of 30kg then we end up with 66 rolls of equal weight and equal diameter and 1 roll slightly less heavy and in total that makes 67 rolls.
Which formulas would we need to employ in order to find how much space(%) these rolls will occupy in a 40HC container?
