How do you go about finding the integer solutions for something like that? : $$a^bx + c^dy$$ where $a,b,c,d$ are positive integers and $a$ is odd and $c$ is even
Using bezouts idenity we know that there exists solutions for: $$a^bx + c^dy = gcd(a^b, c^d)$$ and since $a^b, c^d$ share no common factors $$a^bx + c^dy =1$$
The problem is, how do you apply Extended Euclidean algorithm on $a^b, c^d$ (Obviously it's so easy to if you plug some values in, but I am trying to find a general solution)
I even tried to find one solution just by playing around with the equation but I doubt it works:
$$a^b(\frac {c^d + 1} {a^b}) + c^d(-1) = 1$$
Since $c$ is even then $c^d$ is even then $(c^d + 1)$ is odd
The only thing left is to check the divisblity
Since $a$ is odd then $a^d$ is odd
But Of, course this entire solution is wrong since $(c^d + 1)$ is not necessarily divisible by $a^d$ but you get idea. I need a general solution like the one I provided.
Btw, I am not asking for a solution, some hint would be more than enough except if the equation I provided is unsolvable, In this can case plz tell me so.
Thanks in advance.
