Prove that if $A$ and $B$ are $3\times 3$ matrices over the field $F$, a necessary and sufficient condition that $A$ and $B$ be similar over $F$ is that they have the same characteristic polynomial and the same minimal polynomial.
My attempt: $(\Rightarrow)$ It’s trivial, and holds for $n\times n$ matrices. $(\Leftarrow)$Let $f_A$ and $f_B$ be characteristic polynomial of $A$ and $B$, respectively. Let $m_A$ and $m_B$ be minimal polynomial of $A$ and $B$, respectively. We first prove for $n=2$. Suppose $A,B\in M_{2\times 2}(F)$. We claim $A\backsim B$$\iff$$m_A=m_B$. Suppose $m_A=m_B=m$. Clearly degree of minimal polynomial can’t be zero. Case (1): $\deg (m)=1$. Then $m=x-c$. By example 2 section 7.2, $A,B\backsim \begin{bmatrix} c& 0\\ 0&c\\ \end{bmatrix}$. Since $\backsim$ is an equivalence relation, we have $A\backsim B$. Case (2): $\deg (m)=2$. Then $m=x^2+c_1x+c_0$. By example 2 section 7.2, $A,B\backsim \begin{bmatrix} 0& -c_0\\ 1& -c_1\\ \end{bmatrix}$. Since $\backsim$ is an equivalence relation, we have $A\backsim B$.
Following is slight generalisation of example 2. Suppose $\dim (V)=3$ and $T:V\to V$ be a linear operator. Let $m$ and $f$ be minimal and characteristic polynomial of $T$, respectively. Case (1): $\deg (m)=3$. Then $m=x^3+c_2x^2+c_1x+c_0$. By Cayley-Hamilton theorem, $m=f$. By theorem 3 corollary 2 section 7.2, $T$ has a cyclic vector. That is $\exists \alpha \in V$ such that $V=Z(\alpha ;T)$. By theorem 2 section 7.1, $\exists \mathcal{B}$ basis of $V$ such that $[T]_\mathcal{B}$ is companion matrix of $m$. So $[T]_\mathcal{B}=\begin{bmatrix} 0&0&-c_0\\ 1&0&-c_1\\ 0&1&-c_2\\ \end{bmatrix}$. Case (2): $\deg (m)=2$. Then $m=x^2+c_1x+c_0$. By cyclic decomposition theorem, $\exists \alpha_1,…,\alpha_r\in V\setminus \{0\}$ with respective $T$-annihilators $p_1,…,p_r$ such that $V=Z(\alpha_1;T)\oplus \cdots Z(\alpha_r;T)$, and $p_{i+1}|p_i$, and $p_1\cdots p_r=f$, and $p_1=m$. So $\deg (p_1)=\deg (m)=2$. By theorem 1 section 7.1, $\dim Z(\alpha_1,T)=\deg (p_1)=2$. Which implies $r=2$ and $\dim Z(\alpha_2;T)=\deg (p_2)=1$. Let $p_2=x-d$. So $\exists \mathcal{B}$ basis of $V$ such that $[T]_B= \begin{bmatrix} 0&-c_0&0\\ 1&-c_1&0\\ 0&0&d\\ \end{bmatrix}$. Case (3): $\deg (m)=1$. Then $m=x-c$ and $T=cI$. So $[T]_\mathcal{B}= \begin{bmatrix} c&0&0\\ 0&c&0\\ 0&0&c\\ \end{bmatrix}$, for any basis $\mathcal{B}$ of $V$. By theorem 5 section 7.2, every $3\times 3$ matrix over $F$ is similar to exactly one matrix of the types $$\begin{bmatrix} 0&0&-c_0\\ 1&0&-c_1\\ 0&1&-c_2\\ \end{bmatrix}, \quad \begin{bmatrix} 0&-c_0&0\\ 1&-c_1&0\\ 0&0&d\\ \end{bmatrix}, \quad \begin{bmatrix} c&0&0\\ 0&c&0\\ 0&0&c\\ \end{bmatrix}.$$
We show for $n=3$. Suppose $A,B\in M_{3\times 3}(F)$, $f_A=f_B=f$ and $m_A=m_B=m$. Case (1): $\deg (m)=1$. Then $m=x-c$. By above result, $A,B\backsim \begin{bmatrix} c&0&0\\ 0&c&0\\ 0&0&c\\ \end{bmatrix}$. Since $\backsim$ is an equivalence relation, we have $A\backsim B$. Case (2): $\deg (m)=2$. Then $m=x^2+c_1x+c_0$. By above result, $A\backsim \begin{bmatrix} 0&-c_0&0\\ 1&-c_1&0\\ 0&0&d\\ \end{bmatrix}$ and $B\backsim \begin{bmatrix} 0&-c_0&0\\ 1&-c_1&0\\ 0&0&d’\\ \end{bmatrix}$ such that $m(x-d)=f_A$ and $m(x-d’)=f_B$. Since $f_A=f_B$, we have $d=d’$. Since $\backsim$ is an equivalence relation, we have $A\backsim B$. Case (3): $\deg (m)=3$. Then $m=x^3+c_2x^2+c_1x+c_0$. By above result, $A,B\backsim \begin{bmatrix} 0&0&-c_0\\ 1&0&-c_1\\ 0&1&-c_2\\ \end{bmatrix}$. Since $\backsim$ is an equivalence relation, we have $A\backsim B$. Is my proof correct?
user264745
  • 4,143
    I think it is correct, but I cannot see the usefulness of everything before "By theorem 5 section 7.2, every 3×3 matrix over F is similar to...". – Anne Bauval Feb 22 '23 at 16:17
  • @AnneBauval what exactly do you mean by “usefulness before theorem 5 section 7.2”? I assume you meant, we can reach to desired conclusion (every $3\times 3$ matrix is similar to exactly one matrix of the types) without doing all the stuff that I did in second paragraph. If that’s what you meant, then it is not true, I think. Your solution is bit out of reach for me right now. I will definitely revisit your solution in future. – user264745 Feb 22 '23 at 16:48
    Alternatively: wlog F is algebraically closed and (inspecting the few cases) distinct Jordan decompositions give distinct pairs $(m,f).$ – Anne Bauval Feb 22 '23 at 16:59
    Yes this is what I meant. You don't seem to use it. I may be partially wrong. I have to think. – Anne Bauval Feb 22 '23 at 17:00
  • @AnneBauval Suppose $A\in M_{3\times 3}(F)$. Let $T:F^3\to F^3$ defined by $[T]{B’}=A$, where $B’$ is canonical basis of $F^3$. Let $m_T$ and $m_A$ be minimal polynomial of $T$ and $A$. By this post, $m_T=m_A$. Now there are three possibilities (1) $\deg (m_A)=3$, (2) $\deg (m_A)=2$, and (3) $\deg (m_A)=1$. If (1), then $\exists \mathcal{B}$ basis of $V$ such that $[T]\mathcal{B}$ is companion matrix of $m_A$. We know $A=[T]{B’}\backsim [T]\mathcal{B}$. Similarly for (2) and (3). – user264745 Feb 22 '23 at 17:18
  • @AnneBauval Suppose $B\in M_{3\times 3}(F)$. Let $U:F^3 \to F^3$ defined by $[U]{B’}=B$, where $B’$ is canonical basis of $F^3$. As we showed in previous comment, $m_U=m_B$ If (1), then $\exists \mathcal{B}’$ basis of $V$ such that $[U]{\mathcal{B}’}$ is companion matrix of $m_B$. We know $B=[U]{B’}\backsim [U]{\mathcal{B}’}$. Since $m_A=m_B$, we have $[T]\mathcal{B}=[U]{\mathcal{B}’}$. Hence $A\backsim [T]\mathcal{B}=[U]{\mathcal{B}’}\backsim B$. – user264745 Feb 22 '23 at 17:39
    Yes (why twice?) all this was already in your post (and does not seem to use what is before "By theorem 5 section 7.2..."). I don't understand the aim of these two comments. – Anne Bauval Feb 22 '23 at 18:51
  • @AnneBauval we did use stuff before “By theorem 5 section 7.2”. In particular, existence of basis $\mathcal{B}$ such that $[T]_\mathcal{B}$ is companion matrix of $m_A$. And we exhausted only one possibility, $\deg (m_A)=3$. My aim for those two comments was to show you stuff before “By theorem 5 section 7.2” is required/necessary. – user264745 Feb 22 '23 at 18:59
Two long for a comment. Just to explain why I think all the "stuff before “By theorem 5 section 7.2” is useless.
By theorem 5 section 7.2, $A$ is similar to a matrix of one the following three forms, which we shall call canonical: $$\begin{pmatrix} 0&0&-c_0\\ 1&0&-c_1\\ 0&1&-c_2\end{pmatrix}, \quad \begin{pmatrix} 0&-c_0&0\\ 1&-c_1&0\\ 0&0&d\end{pmatrix},\quad\begin{pmatrix} c&0&0\\ 0&c&0\\ 0&0&c\end{pmatrix}$$ where in the second form, $X-d\mid X^2+c_1X+c_0.$
The characteristic polynomials of these three matrices are respectively $$X^3+c_2X^2+c_1X+c_0,\quad(X^2+c_1X+c_0)(X-d),\quad(X-c)^3$$ and the minimal polynomials are also easily computed: $$X^3+c_2X^2+c_1X+c_0,\quad X^2+c_1X+c_0,\quad X-c.$$ Therefore, the characteristic and minimal polynomials of $A$ determine completely which canonical form it is similar to. Hence two matrices having the same characteristic and minimal polynomials are similar.
user264745
  • 4,143
Anne Bauval
  • 34,650
  • Thank you for the answer. Lemma “$A$ is similar to a matrix of one of the following three forms” requires a proof, and that’s what I did in second paragraph. I don’t immediately see “characteristic and minimal polynomials of $A$ determine completely which canonical form it is similar to”. It need details. – user264745 Feb 22 '23 at 20:04
  • Minimal polynomial of $A$ determine completely which canonical form it is similar to. It’s proof is basically second paragraph. – user264745 Feb 22 '23 at 20:54
    "$A$ is similar to a matrix of one of the following three forms" required no additional proof: it is a mere application of "theorem 5 section 7.2" (the "stuff before" essentially consists in re-proving this theorem in dimension 3). And neither did "characteristic and minimal polynomial of $A$ determine...": it is immediate from the observation of the pair (characteristic polynomial,minimal polynomial) for each canonical form: for distinct canonical forms, the pairs are distinct. – Anne Bauval Feb 22 '23 at 21:55
