Let $V$ be an $n$-dimensional vector space, and let $T$ be a linear operator on $V$. Suppose that $T$ is diagonalizable.
(a) If $T$ has a cyclic vector, show that $T$ has $n$ distinct characteristic values.
(b) If $T$ has $n$ distinct characteristic values, and if $\{\alpha_1,…,\alpha_n \}$ is a basis of characteristic vectors for $T$, show that $\alpha =\alpha_1+…+\alpha_n$ is a cyclic vector for $T$.
My attempt: (a) Let $m$ be minimal polynomial of $T$. By theorem 6 section 6.4, $T$ is diagonalizable$\iff$$m$ is of form $(x-c_1)\cdots (x-c_k)$, where $c_i\in F$ and $c_i\neq c_j$, if $i\neq j$. Since $T$ has a cyclic vector, we have $\exists \alpha \in V$ such that $Z(\alpha ;T)=V$. Let $p_\alpha$ be $T$-annihilator of $\alpha$. By theorem 1 section 7.1, $\deg (p_\alpha)=\dim Z(\alpha;T)=n$ and $p_\alpha =m$. So $\deg (m)=n$. Thus $m=(x-c_1)\cdots (x-c_n)$, where $c_i\in F$ and $c_i\neq c_j$, if $i\neq j$. Since characteristic and minimal polynomial of $T$ have same roots, we have $c_1,…,c_n$ are distinct roots of characteristic polynomial of $T$. That is $c_1,…,c_n$ are distinct eigenvalues of $T$. Hence $T$ has $n$ distinct eigenvalues of $T$.
(b) We need to show $V=Z(\alpha;T)=\text{span}(\{T^k(\alpha)\mid k\geq 0\})$. Let $B=\{\alpha, T(\alpha),…,T^{n-1}(\alpha)\}$. Let $\lambda_1,…,\lambda_n$ are distinct eigenvalues of $T$ and $T(\alpha_i)=\lambda_i\alpha_i$, $\forall i\in J_n$. So $T^i(\alpha)=T^i(\alpha_1+…+\alpha_n)=\lambda_1^i\alpha_1+…+\lambda_n^i\alpha_n$. Suppose $c_0\alpha+c_1T(\alpha)+…+c_{n-1}T^{n-1}(\alpha)=0$, for some $c_i\in F$. Then $$\sum_{i=0}^{n-1}c_iT^i(\alpha)= \sum_{i=0}^{n-1}c_i(\lambda_1^i\alpha_1+…+\lambda_n^i\alpha_n)= \sum_{i=0}^{n-1}c_i \lambda_1^i\alpha_1+…+c_i\lambda_n^i\alpha_n =\left(\sum_{i=0}^{n-1}c_i\lambda_1^i\right)\alpha_1+…+ \left(\sum_{i=0}^{n-1}c_i\lambda_n^i\right)\alpha_n=0.$$ Since $\{\alpha_1,…,\alpha_n\}$ is independent, we have $\sum_{i=0}^{n-1}c_i\lambda_j^i=0$, $\forall j\in J_n$. So $f= \sum_{i=0}^{n-1}c_i x^i\in F[x]$ has $n$ roots, namely $\lambda_1,…,\lambda_n$. Which implies $\deg (f)\geq n$ or $f=0$. Either $\deg (f)\leq n-1$ or $f=0$. So $f=0$. That is $c_i=0$, $\forall 0\leq i\leq n-1$. Thus $B$ is independent. In particular, $|B|=n$. By theorem 4 corollary 2 section 2.3, $\dim Z(\alpha ;T)\geq n$. Since $Z(\alpha;T)$ is subspace of $V$, we have $\dim Z(\alpha;T)\leq n$. Thus $\dim Z(\alpha;T)= n=\dim (V)$. Hence $V=Z(\alpha;T)$. Is my proof correct?
Can we show $\text{span} (B)=Z(\alpha;T)$? First I tired to show $T^n(\alpha)=\lambda_1^n\alpha_1+…+\lambda_n^n\alpha_n \in \text{span}(B)$, but can’t find coefficients to make it work.
