Is it possible to prove, in first-order ZFC, that the axiom of replacement can't generate a set that includes members going arbitrarily high in the cumulative hierarchy, but without using the axiom of replacement itself for the proof? Or in other words, to prove without using replacement that the kind of mapping used by replacement won't include elements in its output image going arbitrarily high in the hierarchy?
If it's helpful, part of the motivation for this question is the issue raised here [1] arguing that the replacement axiom doesn't follow directly from the iterative conception of sets: "When Replacement has been justified according to the iterative conception, the reasoning has in fact been circular as it was in Zermelo [1930a], with some feature of the cumulative hierarchy picture newly adduced solely for this purpose." In particular, one concern you might have with the axiom of replacement, from the standpoint of the iterative conception of sets, is that the mapping in replacement might map to sets arbitrarily high in the hierarchy, so there might be no valid set formed by the image of the mapping (just a class). Now, if you have full ZFC including replacement, then you can show that the mappings used by replacement can never map arbitrarily high in the hierarchy, but what I'm unclear on is whether this can be shown without relying on the axiom of replacement for any part of the proof (since in the context of the linked paper the goal would be to intuitively justify replacement from the iterative conception, and avoid circularity in this justification).
Here is a related question, but for 2nd order ZFC [2]. Note, the answer to this previous question assumes that there is an inaccessible cardinal in the metatheory, but the current question should rely only on the ZFC axioms.
Edit: remove proof sketch for now, since not sure if it was on the right track.
[1] https://www.jstor.org/stable/41472440
[3] Proof that we can't get $\omega + \omega$ without Replacement
