(Motivation) Here is an integral I made up for fun:
$$\int_{-\infty}^{\infty}\frac{\ln\left(1+x^{8}\right)}{x^{2}\left(1+x^{2}\right)^{2}}dx.$$
WolframAlpha doesn't seem to come up with a closed form, but I believe it is
$$2\pi\left(1+\sqrt{4+2\sqrt{2}}\right)-3\pi\left(\ln\left(\sqrt{2}\right)+\operatorname{arctanh}\left(\frac{2}{7}\sqrt{10+\sqrt{2}}\right)\right).$$
(Question) Aside from my attempt below, how else could one solve this? Could there possibly a more elegant method than constructing a 4-keyhole contour?
I will try to shorten my attempt as much as possible because it is quite lengthy. If someone wants to read all of it and find any little mistakes, then I would greatly appreciate it, as someone who is seeking to expand his complex analysis skills.
(Attempt) Let $f(z) = \dfrac{\log(1+z^8)}{z^2(1+z^2)^2}$. Its pole is $z=i$ with an order of $2$. Notice $z=0$ is a removable singularity because we can redefine $f(z) = z^6 -2z^8 +3z^{10}-4z^{12}+O\left(z^{13}\right)$ to make it holomorphic at $z=0$. The branch points of $f(z)$ are obtained by
$$1+z^8=0 \implies z = \exp\left(\frac{i\pi}{8}(2n+1)\right)$$
where $n \in \left\{0, 1, \ldots, 7\right\}.$ Also, let $B_n = \exp\left(\dfrac{i\pi}{8}(2n+1)\right)$. Additionally,
$$\log\left(1+z^{8}\right)=\log\left(\prod_{n=0}^{7}\left(z-B_{n}\right)\right)=\sum_{n=0}^{7}\log\left(z-B_{n}\right)=\sum_{n=0}^{7}\left(\log\left|z-B_{n}\right|+i\operatorname{arg}\left(z-B_{n}\right)\right).$$
Let $A_n(z) = \operatorname{arg}\left(z-B_{n}\right)$. For $n \in \left\{0,1,2,3\right\}$, let $A_n(z) \in \left(\dfrac{\pi}{8}\left(2n+1\right),\dfrac{\pi}{8}\left(2n+1\right)+2\pi\right)$. For $n \in \left\{4,5,6,7\right\}$, let $A_n(z) \in \left(\dfrac{\pi}{8}\left(2n+1\right)-2\pi,\dfrac{\pi}{8}\left(2n+1\right)\right)$.
For convenience, I created this graphic of what the contour looks like. It can also be viewed here.
By Cauchy's Residue Theorem, we have
$$2\pi i\operatorname{Res}(f(z),z=i) = \left(\int_{-R}^{R}+\sum_{k=1}^{8}\int_{\lambda_k}+\sum_{m=0}^{3}\int_{\gamma_m}+\int_{\Gamma}\right)f\left(z\right)dz.$$
Perhaps I will write an addendum explaining how to show the integrals over $\Gamma$ and $\gamma_m$, for each $m$ listed in the sum, go to $0$.
This is how to calculate the residue:
$$2\pi i\operatorname{Res}\left(\dfrac{\log(1+z^8)}{z^2(1+z^2)^2},z=i\right) = 2\pi i\cdot\frac{1}{\left(2-1\right)!}\lim_{z \to i}\frac{d^{2-1}}{dz^{2-1}}\frac{\log\left(1+z^{8}\right)\left(z-i\right)^{2}}{z^{2}\left(z+i\right)^{2}\left(z-i\right)^{2}} = 2\pi-\frac{3\pi}{2}\ln\left(2\right)$$
after some basic calculus grunt work.
This is how to calculate the $\lambda_1$ and $\lambda_2$ integrals:
$$ \begin{align} & \lim_{\epsilon \to 0}\lim_{\lambda_1,\lambda_2 \to \Lambda_0}\lim_{R\to\infty}\left(\int_{\lambda_1}f(z-i\epsilon)d(z-i\epsilon) + \int_{\lambda_2}f(z+i\epsilon)d(z+i\epsilon)\right) \\ =&-\lim_{R\to\infty}\lim_{\epsilon\to 0}\int_{e^{i\pi/8}}^{Re^{i\pi/8}}\frac{d(z-i\epsilon)}{(z-i\epsilon)^2(1+(z-i\epsilon)^2)^2}\cdot \left(\log|1+(z-i\epsilon)^8|+i\sum_{n=0}^{7}A_n(z-i\epsilon)\right) \\ &+\lim_{R\to\infty}\lim_{\epsilon\to 0}\int_{e^{i\pi/8}}^{Re^{i\pi/8}}\frac{d(z+i\epsilon)}{(z+i\epsilon)^2(1+(z+i\epsilon)^2)^2}\cdot \left(\log|1+(z+i\epsilon)^8|+i\sum_{n=0}^{7}A_n(z+i\epsilon)\right) \\ =& -2\pi i\int_{e^{i\pi/8}}^{i\infty}\frac{dz}{z^{2}\left(1+z^{2}\right)^{2}} \tag{1}\\ \end{align} $$ where in $(1)$ we used $\displaystyle \lim_{\epsilon \to 0}A_0(z-i\epsilon) = \dfrac{\pi}{8}+2\pi$ and $\displaystyle \lim_{\epsilon \to 0}A_0(z+i\epsilon) = \dfrac{\pi}{8}.$ Since
$$\int \frac{dz}{z^2(1+z^2)^2} = -\frac{3}{2}\arctan\left(z\right)-\frac{3z^{2}+2}{2z^{3}+2z}+C,$$
we can use the Fundamental Theorem of Line Integrals to get the desired integral over $\Lambda_0$ to be
$$-2\pi i\left(e^{-\frac{i\pi}{8}}+\frac{1}{4}\sec\left(\frac{\pi}{8}\right)-\frac{3}{2}\arctan\left(e^{-\frac{i\pi}{8}}\right)\right).$$
We can apply this same sort of process for the other $\lambda$ integrals. After a lot of work, combining those contributions ultimately yields
$$3\pi\operatorname{arctanh}\left(\frac{2}{7}\sqrt{10+\sqrt{2}}\right)-2\pi\sqrt{4+2\sqrt{2}}.$$
Finally, we put everything together:
$$2\pi-\frac{3\pi}{2}\ln\left(2\right)=\int_{-\infty}^{\infty}\frac{\log\left(1+z^{8}\right)}{z^{2}\left(1+z^{2}\right)^{2}}dz+3\pi\operatorname{arctanh}\left(\frac{2}{7}\sqrt{10+\sqrt{2}}\right)-2\pi\sqrt{4+2\sqrt{2}}+0+0+0+0+0.$$
In conclusion, the integral in question equals
Any answer/comment shedding some light is appreciated.
