Does $f = \dfrac{\sin(x)}{\sqrt{x}}$ make it?
I know that $\int \limits_{0}^\infty \dfrac{\sin^2(x)}{x}dx = \infty$, but does $\int \limits_{0}^\infty \dfrac{|\sin(x)|}{|x|}dx < \infty$?
What would be a good example?
$\int \limits_{0}^\infty \dfrac{|\sin(x)|}{|x|}dx = \infty$
and
$\int \limits_{0}^\infty \dfrac{|\sin(x)|}{\sqrt x}dx = \infty$ (which is more relevant here).
$f(x)=\frac 1 {\sqrt x}$ for $0<x<1$, $f(x)=2-x$ for $1\leq x <2$ and and $f(x)=0$ for $x\geq 2$ gives such a function.
Consider
$$f_n(x)=\begin{cases}n(1-n^3|x-n|) &\mathrm{if}\,|x-n|<\frac1{n^3}\\0& \mathrm{otherwise}\end{cases}$$
That is, $f_n$ is continuous, has a triangular peak at $x$ of height $n$, and is $0$ outside of $[x-\frac{1}{n^3},x-\frac{1}{n^3}]$.
You can compute $\int_0^\infty f_n(x)\,\mathrm{d}x=\dfrac{1}{n^2}$ and $\int_0^\infty (f_n(x))^2\,\mathrm{d}x=\dfrac{2}{3n}$.
Let $f(x)=\sum_{n=2}^\infty f_n(x)$. Then $f$ is continuous on $[0,+\infty)$, $\int_0^\infty f(x)\,\mathrm{d}x$ is bounded, while $\int_0^\infty (f(x))^2\,\mathrm{d}x$ is not.
Consider the following fact.
Let $$f(x) = \begin{cases} \frac{1}{|x|^{a}} & |x|\leq1, \\ 0 & \text{else}. \end{cases}$$Then $f\in L^{1}(\mathbb{R}^{n})$ $\iff$ $a<n.$
