Let $V$ be a finite-dimensional vector space and let $W_1,…,W_k$ be subspaces of $V$ such that $V=W_1+…+W_k$ and $\dim(V)=\dim(W_1)+…+\dim (W_k)$. Prove that $V=W_1\oplus …\oplus W_k$.
Approach (1): Suppose $V=W_1+…+W_k$ and $\dim(V)=\sum_{i=1}^k \dim (W_i)$. Then $\dim (V)=\dim (W_1+…+W_k)= \sum_{i=1}^k \dim (W_i)$. By theorem 6 section 2.3, $\dim (W_1+…+W_k)=\dim (W_1)+\dim (\sum_{i\gt 1}W_i)-\dim (W_1\cap \sum_{i\gt 1}W_i)$. By mathematical induction, $$\dim (W_1+…+W_k)=\sum_{i=1}^k \dim (W_i)-\sum_{j=1}^{k-1} \dim(W_j\cap \sum_{i\gt j}W_i).$$ So $\sum_{j=1}^{k-1} \dim(W_j\cap \sum_{i\gt j}W_i)=0$. Since $\dim(W_j\cap \sum_{i\gt j}W_i) \geq 0$, we have $\dim (W_j\cap \sum_{i\gt j}W_i)=0$. So $W_j\cap \sum_{i\gt j}W_i=\{0_V\}$, for all $1\leq j\leq k-1$. By lemma 1 section 6.6, $W_1,…,W_k$ are independent. Thus $V=W_1\oplus … \oplus W_k$. Is my proof correct?
Approach (2): Let $B_i$ be basis of $W_i$, $\forall i\in J_k$. Let $B=\bigcup_{i=1}^k B_i$. We show $B$ is basis of $V$. Since $V=W_1+…+W_k$, we have $V=\text{span} (B)$. Since $\dim (V)=\dim(W_1)+…+\dim (W_k)=n$, we have $\dim(W_1)+…+\dim (W_k)=|B_1|+…+|B_k|$. How to show $B_i\cap B_j=\emptyset$, if $i\neq j$? so that we can conclude $|B_1|+…+|B_k|=|B|=n$.
user264745
  • 4,143
(1) is correct. In (2), the notation $\cup$ is troublesome. Let us view basis as indexed families rather than sets. Denote $B_i=(v_{i,1},\dots,v_{i,n_i})$ and $B=(v_{1,1},\dots,v_{1,n_1},\dots,v_{k,1},\dots,v_{k,n_k})$ (thus allowing a priori repetitions but we shall soon see there are none). Since $n_1+\dots+n_k=\dim V$ and $\operatorname{span}(B)=V,$ $B$ is a basis of $V.$
Anne Bauval
  • 34,650
  • Thank you so much for the answer. You’re correct. I’m using the term basis loosely. It should be ordered basis. But that don’t effect our problem, I think. We need to show cardinality of $B=(B_1,…,B_k)$ is indeed $\dim (V)$. We know $|B_1|+…+|B_k|=n_1+…+n_k=\dim (V)$. What if $\exists \alpha \in B_i\cap B_j$ for some $i\lt j$? Then clearly $|B|\lt \dim (V)$. So $B$ is not basis of $V$. – user264745 Jan 26 '23 at 18:09
    $B$ is not a set but an indexed family (possibly with repetitions a priori). So "$|B|$" and "$B_i\cap B_j$" are not relevant here. $B$ is sequence of $\dim(V)$ vectors. When $n$ vectors span a space of dimension $n$, they are necessarily linearly independent. – Anne Bauval Jan 26 '23 at 18:14
  • To my understanding, if a finite sequence has two same element, then that sequence is linearly dependent. – user264745 Jan 26 '23 at 18:17
    Yes, so we proved this cannot happen for $B,$ but this would not have been sufficient. We proved much more. – Anne Bauval Jan 26 '23 at 18:21
    Wait a second. I saw “no subset of $V$ which contains fewer than $n$ vectors can span$(V)$” result in the book. Thus $|B|=n$. Thank you so much for helping me. – user264745 Jan 26 '23 at 18:29
    I would not formulate it in terms of sets but rather of sequences: if a family $(v_1,\dots,v_n)$ spans a space of dimension $n$ then that family is linearly independent, i.e. $\sum\lambda_iv_i=0\implies\forall i;\lambda_i=0$ (and therefore $v_i\ne v_j$ if $i\ne j$ but this is much weaker). – Anne Bauval Jan 26 '23 at 18:33
    If you use on the result you quote, you obtain that $|B|=n$ but that is not the end of the story. You will have to use anyway the stronger theorem stating that if $|B|=n$ and $B$ spans $V$ (of dimension $n$) then $B$ is a basis for $V.$ So, better use this stronger theorem directly. – Anne Bauval Jan 27 '23 at 07:52
  • Yess. I’m so used to using set (maybe because of the book) that sequence feels bit uncomfortable. But I know sequence is better object to work with in this context, because it has “order” and element can repeat. – user264745 Jan 27 '23 at 08:15
