Let's start with very minimal assumptions -- nothing about how the host chooses a door:$$
P(C1)=P(C2)=P(C3)=\tfrac{1}{3}\\
P(C1,C2)=P(C1,C3)=P(C2,C3)=0\\
P(Xi|Cj)=P(Xi) \forall i, j\\
P(Hi|Xi)=0 \\
P(Hi|Ci)= 0
Given the situation in the article, we want $P(C1|X1, H3)$ and $P(C2|X1, H3)$.
$$P(C1|X1, H3)=\frac{P(H3, X1|C1) P(C1) }{P(X1, H3)}\\
P(H3, X1|C1)=P(H3|X1,C1)P(X1|C1)\\
P(X1, H3)=P(H3|X1)P(X1)\\
P(C1|X1, H3)=\frac{P(H3|X1,C1)P(X1|C1)P(C1)}{P(H3|X1)P(X1)}
The same formulas apply for $C2$. By our initial assumptions, we get some cancellation: $$
P(C1|X1, H3)=\frac{P(H3|X1,C1)\tfrac{1}{3}}{P(H3|X1)}\\
P(C2|X1, H3)=\frac{P(H3|X1,C2)\tfrac{1}{3}}{P(H3|X1)}
$P(H3|X1,C2)=1$ (host can't open the door with the car behind it), so:$$
P(C2|X1, H3)=\tfrac{1}{3}\frac{1}{P(H3|X1)}
Since $C1$, $C2$, and $C3$ are mutually exclusive and sum to 1, $P(H3|X1)=P(H3|X1,C1)P(C1)+P(H3|X1,C2)P(C2)+P(H3|X1,C3)P(C3)$
$P(H3|X1,C2)=1$ and $P(H3|X1,C3)=0$ so $P(H3|X1)=P(H3|X1,C1)P(C1)+P(C2)=\tfrac{1}{3}(P(H3|X1,C1)+1)$
If $P(H3|X1,C1)=\tfrac{1}{2}$, then $P(H3|X1)=\tfrac{1}{2}$ -- but only in that case. If the host hates door 3, and never chooses it unless they have to, $P(H3|X1,C1)=0$ and $P(H3|X1)=\tfrac{1}{3}$.
This makes for:$$
P(C2|X1, H3)=\frac{1}{(P(H3|X1,C1)+1)}\\
P(C1|X1, H3)=\tfrac{1}{3}\frac{P(H3|X1,C1)}{P(H3|X1)}=\frac{P(H3|X1,C1)}{(P(H3|X1,C1)+1)}
This looks like a pretty clear dependence on the host's strategy -- why?
Let's look at it from another angle: if the host and player were in cahoots, but couldn't communicate except through the game (but could coordinate in advance) -- could the host give the player a hint, through their choice of door?
Suppose the host always opens the lowest numbered door they can. In that case, we have:
C1 |
C2 |
C3 |
X1 |
H2 |
H3 |
H2 |
X2 |
H3 |
H1 |
H1 |
X3 |
H2 |
H1 |
H1 |
If player picks 1, and the host responds 2 (X1, H3), the player would know that the car is behind 2 (C2) for sure.
Knowing nothing about the host's strategy, the player should use $1/2$ -- but that's not entirely satisfying -- because it seems like the host can influence the player's chances!
We can take a step back in the game, and look at the odds of the player winning, from the host's perspective. Call their final choice $Y$; take $X1$ as a given.
P(Y1, X1, C1)+P(Y2, X1, C2)+P(Y3, X1, C3)=P(Y1, H2, X1, C1)+P(Y1, H3, X1, C1)+P(Y2, H3, X1, C2)+P(Y3, H2, X1, C3)=P(Y1| H2, X1, C1)P(H2, X1, C1)+P(Y1|H3, X1, C1)P(H3, X1, C1)+P(Y2|H3, X1, C2)P(H3, X1, C2)+P(Y3| H2, X1, C3)P(H2, X1, C3)\\
=P(Y1| H2, X1, C1)P(H2|X1, C1)P(X1,C1)+P(Y1|H3, X1, C1)P(H3| X1, C1)P(X1,C1)+P(Y2|H3, X1, C2)P(H3| X1, C2)P(X1,C2)+P(Y3| H2, X1, C3)P(H2| X1, C3)P(X1,C3)
Using $P(X1)=1$ and simplifying the cases where the host has no choice:$$
P(Y1, X1, C1)+P(Y2, X1, C2)+P(Y3, X1, C3)=P(Y1| H2, X1, C1)P(H2|X1, C1)\tfrac{1}{3}+P(Y1|H3, X1, C1)P(H3| X1, C1)\tfrac{1}{3}+P(Y2|H3, X1, C2)\tfrac{1}{3}+P(Y3| H2, X1, C3)\tfrac{1}{3}
$P(Y1| H2, X1, C1)$ and $P(Y1|H3, X1, C1)$ are both "keep the same door" for the player. Say the player does that with probability $x$. Then the other two terms are "remaining door," chosen with probability $1-x$.
Then: $$
P(Y1, X1, C1)+P(Y2, X1, C2)+P(Y3, X1, C3)=\tfrac{1}{3}(x (P(H2|X1, C1)+P(H3| X1, C1))+2(1-x))
$P(H2|X1, C1)+P(H3| X1, C1)=1$ because the host has to choose one of H2 or H3. This leaves $\tfrac{1}{3}(2-x)$ as the odds of winning. This is maximized by $x=0$, regardless of how the host chooses a door.
