Let $K$ be an arbitrary field, $p$ a prime and $a\in K$. Show $f=x^p-a$ is either irreducible in $K[x]$ or has a root in $K$.
My strategy was to split this up into a case for each characteristic.
The characteristic $p$ case is easy. Assume $f$ is reducible $=gh$ both smaller degree $g$ irreducible, with $\alpha$ a root of $g$. Then in $K(\alpha)[x]$, $f=(x-\alpha)^p$. So $g=(x-\alpha)^k$, and all the other factors of $f$ are of the same form. Hence they are all equal to the $minpoly(\alpha)$ and the degree of $minpoly(\alpha)|p$ so it is $1$ or $p$ and we are done.
The characteristic $0$ case and characteristic $q\ne p$ I get stuck on. If $K$ contains a primitive $p$th root of unity $\zeta$, then over $K(\alpha)$, $f$ splits into linear factors. So the degree of the field extension for any root of $f$ is the same, so the degree of such a root is either $1$ or $p$. If $K$ does not have a primitive $p$th root of unity, then simply adjoin one. We know $[K(\zeta):K]|p-1$ and by the previous step either $f$ is irreducible over $K(\zeta)$ or splits into linear factors. If it is irreducible we are done, if not we have it splits into linear factors of the form $x-\zeta^ia^{1/p}$, but I am unsure what to do from here. The characteristic $q$ case seems similar to the characteristic $0$ case but again I am stuck trying to finish the proof.
Some googling has lead me to believe that this problem is generally approached using the field norm and if an accessible online reference exists I would love to see it, but I feel that in the context I have seen it should be entirely possible that this is done without needing the norm. As I have not seen the field norm before, I would like to know if there is a possible way to prove this without using it and hopefully that follows in the same vein my attempt at a proof did.
