I have a generator matrix G for a Markov chain in continuous time and finite state space and I am looking to prove that the entries of $e^{tG} \geq 0 $
By definition $G = P'(0)$ with entries $g_{ij} = p_{ij} '(0)$
Where $p_{ij}(t) = Prob[X_j = t | X_i = 0]$
There are 2 cases to take into account:
$i≠j$:
$$g_{ij} = \lim_{t\to 0} \frac{p_{ij}(t) - p_{ij}(0)}{t} = \lim_{t\to 0} \frac{p_{ij}(t) - 0}{t}$$
$$\Rightarrow g_{ij}\geq 0, (p_{ij}(t) \in [0,1])$$
$i=j:$
$$g_{ii} = \lim_{t\to 0} \frac{p_{ii}(t) - p_{ii}(0)}{t} = \lim_{t\to 0} \frac{p_{ii}(t) - 1}{t}$$
$$\Rightarrow g_{ii} \leq 0, (p_{ii}(t) \in [0,1])$$
Now I know that the diagonal entries of G are $\leq 0$ and the off-diagonal entries are $\geq 0$.
I know that $e^{tG}= \sum_{n=0}^\infty \frac{(tG)^n}{n!}$
I also know that I could let $R$ be the matrix of eigenvectors of $G.$
$\Rightarrow R^{-1}GR = D $, where $D$ is a diagonal matrix with eigenvalues of $G$ as its entries.
$\Rightarrow G = RDR^{-1}$ $\Rightarrow e^{tG} = Re^{tD}R^{-1}$
And $e^{tD}$ is going to be a diagonal matrix with non-negative entries.
What I'm having a problem with is now proving that $e^{tG}_{ij} \geq 0$ , for all $i,j,$ knowing the above.
Siz
  • 33
  • Oops, can anyone help me out with formatting this a little better. Thank you. – Siz Aug 05 '13 at 12:44
  • For future reference, to get the typed math to format properly, you need to surround it in dollar signs. – user15464 Aug 05 '13 at 12:58
  • I'm not sure as to why you would have to assume that the chain is irreducible; could you elaborate on this? If I'm not mistaken G = 0 only if none of the states communicate. – Siz Aug 05 '13 at 14:02
Pick some $a$ such that $a\geqslant-g_{ii}$ for every $i$ (this assumes the state space is finite). The matrix $G_a=G+aI$ has only nonnegative entries hence, for every $n\geqslant0$, so has $(G_a)^n$.
Now, $\mathrm e^{tG_a}=\sum\limits_{n\geqslant0}(t^n/n!)(G_a)^n$ is a linear combination with nonnegative coefficients of matrices with nonnegative entries, hence $\mathrm e^{tG_a}$ has only nonnegative entries, and $\mathrm e^{tG}=\mathrm e^{-ta}\mathrm e^{tG_a}$ hence $\mathrm e^{tG}$ has only nonnegative entries.
Did
  • 279,727
