I have recently learnt to find some limits and values of some series using integration. This is called as evaluating series and limits using limit as a sum in my textbook.
Now, I tried to derive this series using what I learnt. (It is not part of my textbook. I was just doing this for my own fun):
$$\sum_{r=1}^\infty\frac{1}{r^2}= \frac{π^2}{6}$$
Here is what I did :
Let $S = \lim_{n\to\infty}\sum_{r=1}^n\frac{1}{r^2}$
Using change of variable of $n\to n^2$ and $r\to r^2$, call $n^2 = x$ and $r^2 = y$, we have :
$$S=\lim_{x\to\infty}\frac{1}{x}\sum_{y=1}^x\frac{x}{y}$$
Now using limit as a sum formula, we have :
$$S = \int_0^1\frac{1}{x}dx=\infty$$
Of course this is wrong.
Where did I went wrong? Can you provide a correct proof of this series using this limit as a sum integration method?
(There is a famous question of this series on this site but on the answers to that, I didn't find a solution involving limit as a sum method. Hence my question is different.)
An_Elephant
  • 2,704
In the equation:$$S=\lim_{x\to\infty}\frac{1}{x}\sum_{y=1}^x\frac{x}{y}$$The index of the sum should've been $\sqrt{y}$, which is a bit complicated to work with.
Kamal Saleh
  • 6,497
  • If we plug back our substitution values, we get : $\lim_{x\to\infty}\frac{1}{x}\sum_{y=1}^x\frac{x}{y}=$$\lim_{n^2\to \infty} \sum_{r^2 = 1}^n^2 \frac{1}{r^2}$ – An_Elephant Dec 19 '22 at 15:39
  • @An_Elephant Yes, you are right. This is why the index should've been $\sqrt{y}$, which technically could happen, nothing wrong about that, but it might be the reason why the sum diverges. – Kamal Saleh Dec 19 '22 at 15:41
  • I also thought that the wrong-ness would be in substitution. However, I still can't understand why is it because because variables reach same value of limit. Can you elaborate more in the answer. Thanks – An_Elephant Dec 19 '22 at 15:45
  • @An_Elephant Your substitution for $x$ is fine since $\sqrt{x}\rightarrow\infty$ so $x\rightarrow\infty$, but when you change the index of the sum from $y=1$ to $\sqrt{y}=1$ you actually get more terms. – Kamal Saleh Dec 19 '22 at 16:11
you could verify below equation using Taylor's expansion
$$\sum_{r=1}^\infty{1\over r^2}=-\int_{0}^1{{ln(1-x)\over x}dx}$$
by substituting $$ln(1-x)=z$$
we get, $$=\int_0^\infty \frac{z}{e^z-1}dz$$
which is called BOSE INTEGRAL and it is solved using complex analysis
a useful link for solving the same problem
