45
I would like examples of uncountable subsets of $\mathbb{R}$ that have zero Lebesgue measure and are not obtained by the Cantor set.
Thanks.
Pedro
  • 18,817
  • 65
  • 127
    "not obtained by the Cantor set"? – OR. Aug 04 '13 at 23:57
    You need to specify what you mean by "not obtained by the Cantor set". Any Borel set (and more) is the image of the Cantor set by a Borel function. – Andrés E. Caicedo Aug 05 '13 at 02:00
    "not obtained by the Cantor set" has no formal meaning. I asked this because all examples of uncountable subsets of $\mathbb{R}$ with zero Lebesgue mesure that I have seen is Cantor set or a set "obtained by Cantor ser", like this: http://math.stackexchange.com/questions/175559/example-of-measure-zero-sets?rq=1 Thanks. – Pedro Aug 06 '13 at 02:56
6 Answers6
32
Let $(r_n)_{n\in\mathbb{N}}$ be a dense sequence in $\mathbb{R}$ (it could, for example, be an enumeration of the rationals). For $k \in \mathbb{N}$, let
$$U_k = \bigcup_{n\in\mathbb{N}} (r_n - 2^{-(n+k)},\, r_n + 2^{-(n+k)}).$$
$U_k$ is a dense open set with Lebesgue measure $\leqslant 2^{2-k}$, thus
$$N = \bigcap_{k\in\mathbb{N}} U_k$$
is a set of the second category (Baire), hence uncountable, and has Lebesgue measure $0$.
Daniel Fischer
  • 206,697
  • Sure, the sequence of centres is already dense. – Daniel Fischer Aug 05 '13 at 00:06
  • I didn't see the union in front of the intervals. – William Aug 05 '13 at 00:06
    I don't know if this counts as being not obtained from a Cantor Set. $N$ is Borel Set. It has the perfect set property. Since $N$ is uncountable, $N = P \cup C$ where $P$ is nonempty perfect and $C$ is countable. So $N$ is really just a Cantor set union a countable set. – William Aug 05 '13 at 00:10
  • @DanielFischer: Awesome!!! (You might link this to the Baire thread) http://math.stackexchange.com/questions/165696/your-favourite-application-of-the-baire-category-theorem – C-star-W-star Oct 29 '14 at 14:50
  • I'm trying to understand the Liouville numbers, or U-numbers, which are uncountable, measure 0 and dense.
    The Cantor set is uncountable, measure 0 and not dense.
    So, could we isomorphize each other?
    – Vinícius Ferraz Jun 22 '16 at 13:08
  • @ViníciusFerraz What do you mean by "isomorphize"? Are you asking whether the sets are homeomorphic? – Daniel Fischer Jun 22 '16 at 13:16
  • I want to classify aleph_1 uncountable sets up to isomorphism. It seems that Liouville's is not isomorphic to Cantor's set. – Vinícius Ferraz Jun 23 '16 at 15:31
  • @ViníciusFerraz What does "isomorphism" mean here? Homeomorphism? Order isomorphism? – Daniel Fischer Jun 23 '16 at 15:36
  • Example: the ring $\mathbb{Z}$ is not iso. to the ring $\mathbb{Q}$. What is necessary and sufficient for X to be ring-isomorphic to $\mathbb{R}$? Example. (0, 1) = Ball(0.5, r = 0.5) $\simeq \mathbb{R}$. Uncountable, aleph_1, dense, Lebesgue measure > 0, in addition to... what? – Vinícius Ferraz Jun 23 '16 at 16:23
  • I'm sorry, @ViníciusFerraz, but that's quite unclear. The interval $(0,1)$ doesn't carry a standard ring structure, so in what sense is it isomorphic to $\mathbb{R}$ when considering ring structures? Of course you can endow every set of cardinality $2^{\aleph_0}$ with a ring structure that makes it isomorphic to $\mathbb{R}$, but that's not particularly interesting. If we have a given ring structure on $X$, then $X$ is ring-isomorphic to $\mathbb{R}$ if and only if it is a complete Archimedean ordered field. Thus the only subring of $\mathbb{R}$ that is isomorphic to $\mathbb{R}$ is – Daniel Fischer Jun 23 '16 at 17:42
  • $\mathbb{R}$ itself. But that isn't particularly interesting either. And neither the Cantor set nor the set of Liouville numbers is a subring of $\mathbb{R}$. – Daniel Fischer Jun 23 '16 at 17:42
  • $\mathbb{Q}$ is the "field of fractions" of $\mathbb{Z}$. Let $C$ be Cantor's set of real numbers. Is $\mathbb{L}$ like the "field of fractions" of $C$? The "densification"? – Vinícius Ferraz Jun 23 '16 at 18:29
  • $C$ isn't a ring, @ViníciusFerraz, I'm lost as to what you want. You should figure out what exactly you want to ask, and ask a question on main. This comment thread is not the right place to find out what you actually are interested in. – Daniel Fischer Jun 23 '16 at 18:37
  • See http://math.stackexchange.com/questions/1610098/example-of-an-uncountable-dense-set-with-measure-zero#comment3752974_1610098
    $[\mathbb{Q} \cap (0,1)] \cup C = A$. I want a function $f : A \rightarrow \mathbb{L}$, which is Liouville's set.
    – Vinícius Ferraz Jun 24 '16 at 18:23
  • @DanielFischer I've some questions regarding to your answer. $U_k$ is dense in which space? Is it dense in $\Bbb R$ ? To show $N$ is of 2nd category by Baire's theorem we have to show $N$ is complete. How I can show that $N$ is complete ? – Empty Sep 02 '17 at 09:51
    @S717717 Yes, it's dense in $\mathbb{R}$ (as a superset of the dense ${r_n:n\in\mathbb{N}}$). We don't need to show that $N$ is complete to see that it's of the second category (in $\mathbb{R}$, also in itself). It's completely metrisable, but it's not complete in the standard metric. Directly from the construction we have $$\mathbb{R}\setminus N=\bigcup_{k\in\mathbb{N}}\bigl(\mathbb{R}\setminus U_k\bigr),$$ that is, $N$ is co-meagre. Since $\mathbb{R}$ is not meagre in itself, it follows that $N$ is not meagre in $\mathbb{R}$. And as a co-meagre set in a Baire space, $N$ is a Baire space. – Daniel Fischer Sep 02 '17 at 10:14
17
Your question is in some part historically related to the investigation of the Continuum Hypothesis CH, i.e. whether every uncountable subset of $\mathbb{R}$ is in bijection with $\mathbb{R}$. A perfect subset is closed set with no isolated points. It is well-known that the Cantor set continuous injects into all perfect subsets. (So perfect sets cardinality $2^{\aleph_0}$.) One way of solving CH was to show whether all uncountable set was the union of a perfect set and an countable set. This is called the perfect set property.
So one way of formalizing your idea of "not obtained from a Cantor Set" is to say that your set is not the Cantor set union a countable set. So taking this interpretation of question, a satisfactory answer would be to produce an uncountable measure zero set without a perfect subset.
Note that without the axiom of choice and with the axiom of determinacy, all uncountable sets have the perfect set property. So in such universe, you will not be able to produce any such example. In particular, if you are working $ZF$ set theory, you will not be able to produce such example (unless the axiom of determinacy is inconsistent, which no one knows.)
I am not sure if such a set exist in ZFC. However, by assuming some more axioms that are shown to be equiconsistent with ZFC, such a set does exist.
$Add(null)$ is the additivity of ideal of measure sets. That is if $\kappa < Add(null)$ is a cardinal, then the union of $\kappa$ many measure zero sets is still measure zero. $ZFC + \neg CH + Add(null) = 2^{\aleph_0}$ is consistent with $ZFC$.
So in such a universe, you can take any the Cantor set $C$ of measure zero. Use the axiom of choice to well order $C = \{a_\xi : \xi < 2^{\aleph_0}\}$. Then $\{a_\xi : \xi < \aleph_1\}$ is an uncountable measure zero set since $\aleph_1 < 2^{\aleph_0} = add(null)$.
You may not be too happy with this example I actually did use a Cantor set and carved out a uncountable measure zero subset. If you would like: Using the axiom of choice there exists disjoint uncountable set $A$ and $B$ such that $A$ and $B$ intersect every perfect subset of $\mathbb{R}$. In particular $A$ is does not contain any perfect subsets. (You can find this construction in $\textit{Descriptive Set Theory}$ 2C.4.) So this $A$ is very different from a Cantor set. In fact, if you look at the construction it is not clear if $A$ is even meaureable. Then apply the same construction above to carve out a uncountable measure zero subset of this set $A$.
So in conclusion, in the equiconsistent extension $ZFC + \neg CH + add(null) = 2^{\aleph_0}$ such a measure set exists. Using only $ZF$ and no choice, no such example can be found (if AD is actually consistent). I am still not sure if $ZFC$ can produce such an example.
William
  • 19,935
  • The answer to the question in your last paragraph is yes, see my answer. (And +1.) – Noah Schweber Mar 02 '17 at 17:48
  • I thought the "perfect set property" was just that every uncountable set contains a perfect set. As for "all uncountable set was the union of a perfect set and an countable set" the set of irrational numbers is a counterexample to that. – bof Aug 05 '19 at 03:01
A very simple example is the set of numbers not normal in base $10$. This set is not obtained from a Cantor set in any way (and is in fact dense in $[0,1)$) and has zero measure and is obviously uncountable. Additionally it has full Hausdorff dimension and is of the second category.
The set of badly approximable numbers works for this, too.
In his answer, William defined "not obtained from the Cantor set" as "not the union of a [perfect] set and a countable set." In particular, any set not containing a perfect set is not obtained from the Cantor set. He then asked whether an uncountable, measure zero set of this type exists provably in ZFC.
The answer is yes. ZFC proves the existence of a Bernstein set - a set $B$ such that for every perfect set $P$, $B\cap P$ and $B^c\cap P$ are each nonempty. Now if $B$ is Bernstein and $P$ is perfect, we have in fact that $B\cap P$ is uncountable and does not contain a perfect set; clearly $B\cap P$ can't contain a perfect set (since then $B^c$ wouldn't meet it), and if $B\cap P$ were countable, then $P\setminus (B\cap P)$ would be an uncountable Borel set, hence (since Borel sets have the perfect set property) would have a perfect subset which would not meet $B$.
OK, so fix a Bernstein set $B$ and a measure zero perfect set $P$ (say, the usual Cantor set) and let $X=B\cap P$. Clearly $X$ has measure zero, and by the above $X$ is uncountable and does not contain a perfect subset, hence is not obtained from the Cantor set in the sense defined in the first paragraph.
Here's a sketch of the ZFC-proof that a Bernstein set exists. We use transfinite induction, and the observation that there are exactly as many reals as perfect sets. At stage $\alpha<2^{\aleph_0}$, look at the $\alpha$th perfect set; pick two reals not already used in this set, and put one of them in $B$, and the other in the complement of $B$. Since perfect sets have size continuum, and by induction we've only used $2\alpha$-many reals so far, we can always find such a pair of reals.
Noah Schweber
  • 245,398
  • How exactly is AC used in this last paragraph? – CuriousKid7 Feb 25 '18 at 08:36
    @CuriousKid7 To set up the transfinite induction, we need to fix well-orderings of the reals and of the perfect sets. This requires choice. – Noah Schweber Feb 25 '18 at 16:55
  • If you just wanted a measure zero set which is "not obtained from the Cantor set" according to William's definition, you could just take $\mathcal C+\mathbb Q$ where $\mathcal C$ is the Cantor set. Of course "not containing a perfect set" is much stronger. – bof Aug 05 '19 at 03:06
Let $E_n \subset [0,1] $ be the set of real numbers whose binary expansion starts with a $n$-bit string which contains at most $\lfloor p\, n \rfloor$ zeroes, for $ 0 \le p < 1/2$. For example, if $ p = 1/3$ then $$ E_3 = [0.011,0.011\bar1]\cup [0.101,0.101\bar1] \cup [0.110,0.110\bar1] \cup [0.111,0.111\bar1]$$ Let $$ E = \bigcap_{k\in\mathbb N} \bigcup_{n \ge k} E_n $$ Then $E$ is uncountable, has zero Lebesgue measure, and I cannot see any connection with the Cantor set.
Denote $E_2^c =$ the set of real numbers $x$ on the interval $[0, 1]$ such that in the decimal form of $x = 0.i_1 i_2 i_3 \dots$ there is no digits $2$.
Write $x \in E_2^c$ in decimal form $$ x = 0. i_1 i_2 i_3 \dots, \ \ i_k = 0, 1, 3, 4, 5, 6, 7, 8, 9, \ \ x = \sum_{k=1}^{\infty} \frac{i_k}{10^k}, $$ and assume that the first digit $2$ appeals at $k$th decimal of $x$.
Denote $E_{2,1}$ as the set of real numbers $x$ on the interval $[0, 1]$ such that the first digit $2$ appeals at $1$th decimal of $x$: $E_{2,1} = \{x | x = 0. 2 \dots\} = [0.2, 0.3)$, then $m(E_{2,1}) = 10^{-1}$;
Denote $E_{2,2}$ as the set of real numbers $x$ on the interval $[0, 1]$ such that the first digit $2$ appeals at $2$th decimal of $x$: $E_{2,2} = \{x | x = 0. i_1 2 \dots\} = \cup_{i_1} [0.i_1 2, 0.i_1 3)$, $i_1 \in \{0, 1, 3, 4, 5, 6, 7, 8, 9\}$, then $m(E_{2,2}) = 9 \times 10^{-2}$;
Inductively, \begin{align} E_{2,k} &= \{x | x = 0. i_1 \dots i_{k-1} 2 \dots\} \\ &= \cup_{i_1, \dots, i_{k-1}} [0. i_1 \dots i_{k-1} 2, 0. i_1 \dots i_{k-1} 3), \end{align} where $i_1, \dots, i_{k-1} \in \{0, 1, 3, 4, 5, 6, 7, 8, 9\}$, then $m(E_{2,k}) = 9^{k-1} \times 10^{-k}$;
Define $E_2 =$ the set of real numbers $x$ on the interval $[0, 1]$ such that in the decimal form of $x = 0.i_1 i_2 i_3 \dots$ there is digits $2$.
Then the measure of $E_2$ is $$ m(E_2) = m(\cup_{k=1}^{\infty} E_{2,k}) = \sum_{k=1}^{\infty} m(E_{2,k}) = \sum_{k=1}^{\infty} 9^{k-1} \times 10^{-k} = 1. $$
Thus, the measure of $E_2^c$ is $$ m(E_2^c) = m([0, 1] \setminus E_2) = m([0, 1]) - m(E_2) = 1 - 1 = 0. $$
Bach
  • 5,730
  • 41
Xiang
  • 41
