Assume to groups, $A$ and $B$, which both are normally distributed with mean $0$ and variance $1$.
What is the probability that $Max_A > Max_B$ if $n_A = n_B$ (say 50)?
What is the probability that $Max_A > Max_B$ if $n_A > n_B$ (say 75 and 25)?
I think my general query is how the maximum distribution depends on $n$ and how that can be used to determine the probability of the maximum values of one group exceeding another.
John12
    in the first case, the problem is symmetrical, so it must be $1/2$ – Exodd Dec 04 '22 at 14:29
  • Agree @Exodd, the intuition is clear on that. However, what is the formal logic? and how can it possibly be extended to varying $n$? – John12 Dec 04 '22 at 14:32
  • You can derive the pdfs/cdfs of a max of a group of $n$ iid sampled elts (from any dist) as $nF(x)^{n-1}f(x)$ where $F$ and $f$ are the cdf and pdf of the dist respectively. The behavior is pretty easy to get a closed form for when the distribution is uniform but for more complex stuff, and for normal dists in particular, it's hard to get a closed form. See this for some discussion. – Vercingetorix Dec 04 '22 at 14:33
  • That being said for q1, it's simply a matter of symmetry and the answer is $0.5$ – Vercingetorix Dec 04 '22 at 14:34
    You don't need to determine the pdfs/cdfs. If the distributions are identical (and continuous), then any permutation of group assignment to a sample is size $n_A+n_B$ is equally likely. The probability that group A has the maximum value is $n_A/(n_A+n_B)$. – JimB Dec 04 '22 at 17:06
If the distributions are identical (and continuous), then any permutation of group assignment to a sample of size $n_A+n_B$ is equally likely. The probability that group A has the maximum value is $n_A/(n_A+n_B)$.
JimB
  • 1,861
