I find it hard to wrap my head around this.
Consider the following harmonic sum:
$$\sum_{k=1}^\infty \frac{1}{k},$$
in which the individual terms obviously converge to $0$ as $k\to\infty$, but the sum diverges.
Then in comparison consider the following geometric sum:
$$\sum_{k=1}^\infty r^k\quad\text{when}\quad\lvert r\rvert <1,$$
in which the individual terms converge to $0$, but apparently fast enough so the sum also converges.
When you plot the first one, it seems as if converging but kind of understandably it is not. Is there any clarifying intuitive ways to approach the difference between the two sums here? The difference seems so slight that it kind of makes the reality feel relative.
I just found one topic which kind of touches on the idea, but focusing on the two different harmonic means. But yea, I am not a mathemathican so my brains might not be wired enough to differentiate between the two I am proposing here. Just to add, of course I understand the basic differences between geometric and harmonic series, but in this particular setting the dynamics seem similar
– Lassi Dec 01 '22 at 16:06
