In showing that $\log^\alpha{(1+x)}$ is $O((x)^\alpha)$ at $1$, for $\alpha>0$, one can note that
$$\left ( \frac{\log{(1+x)}}{x} \right )^\alpha \overset{x\to 0}{\longrightarrow} \left ( 1\right )^\alpha = 1.$$
So we know that $$\log^\alpha{(1+x)}= (x)^\alpha + o((x)^\alpha).$$
But how would I find $\beta > \alpha$ and $c\in \mathbb{R}$ such that
$$\log^\alpha{(1+x)}= (x)^\alpha + c(x)^\beta + o((x)^\beta)?$$
I'd like to raise the power series to an exponent:
$$\log^\alpha(1+x) = \left ( x - x^2/2 + x^3/3 + \dotsb \right) ^ \alpha = \,\,\,??$$
Is there a version of the multinomial theorem I need to use here? This page I found gives me a formula for a multinomial when the first term is larger than the sums of the rest of the terms, but I don't think I want to use that...
Eric Auld
  • 28,127
    You may write $(x+O(x^2))^\alpha$ as $x^\alpha(1+O(x))^\alpha$ and apply binomial expansion to $(1+t)^\alpha$ for $t$ small. – 23rd Aug 01 '13 at 19:20
  • Definitely the latter...let me fix that – Eric Auld Aug 01 '13 at 19:46
  • Is there a general method when one has more than two terms? – Eric Auld Aug 01 '13 at 19:47
    I am not clear how general for what expansion you need. Could you be more specific? – 23rd Aug 01 '13 at 19:51
  • The binomial expansion of $(1+O(x))^\alpha$ gets us up to $O(x)$, and when multiplied by $x^\alpha$, we get $O(x^{\alpha + 1})$. Is there any way to find $c\in \mathbb{R}$ such that $\log^{\alpha}{(1+ x)}=x^{\alpha} + c x^{\alpha + 1} + o(x^{\alpha+1})$? – Eric Auld Aug 01 '13 at 19:57
    Binomial expansion can give you as precise as you wish. For example, up to $t^2$ term, $(1+t)^\alpha=1+\alpha t+\frac{\alpha(\alpha-1)}{2}t^2+O(t^3)$. For $t=O(x)$, you will get $1+\alpha O(x)$; for $t=ax+o(x)$, you will get $1+a\alpha x+o(x)$; for $t=ax+bx^2+o(x^2)$, you will get $1+a\alpha x+(b\alpha+\frac{a^2\alpha(\alpha-1)}{2})x^2+o(x^2)$. – 23rd Aug 01 '13 at 20:07
Landscape has provided a very nice answer in the comments. I will summarize in this community wiki, hoping I am getting it right:
Given a power series to a (possibly fractional) exponent $\alpha > 0$, say the one in the original question:
$$ \left ( x - x^2/2 + x^3/3 + \dotsb \right) ^ \alpha,$$
one can factor out the $x$ term, and truncate at whatever term one desires
$$ x^\alpha \left ( 1 - x/2 + x^2/3 + o(x^2) \right) ^ \alpha$$
and then apply the generalized binomial theorem
$$= x^\alpha \left ( 1 + \alpha\cdot[- x/2 + x^2/3 + o(x^2) ] + \frac {\alpha (\alpha - 1) } {2} [ - x/2 + x^2/3 + o(x^2) ]^2 \\ + o( [ - x/2 + x^2/3 + o(x^2) ]^2) \right) \\ = x^\alpha - \frac {\alpha} {2} x^{\alpha + 1} + \left ( \frac {\alpha} {3} + \frac {\alpha(\alpha-1)} {8} \right )x^{\alpha + 2} + o(x^{\alpha + 2}).$$
Eric Auld
  • 28,127
