This is a simple question (perhaps pedantic) about basic differentiation in real coordinate space. In practice, I don't ever have issues using or carrying out differentiation in $\mathbb{R}^m$. But I'm pretty sure I frequently and severely abuse notation and I'm trying to improve.
question 1: Let $f:\mathbb{R}^m \to \mathbb{R}^n$ be some smooth map between real coordinate spaces. It maps some point $x\in\mathbb{R}^m$ to $y\;\dot{=}\;f(x)\in\mathbb{R}^n$. What is the proper way to write the derivative of $f$ (Jacobian)?
$$ df \quad, \quad \frac{\partial f}{\partial x} \quad, \quad \frac{\partial f(x)}{\partial x} \quad, \quad \frac{\partial y}{\partial x} \qquad ? $$
does $\frac{\partial f}{\partial x}$ even mean anything or do we need to "feed" $f$ some input before we can differentiate as $\frac{\partial f(x)}{\partial x}$? In the last of the above, $y$ is just a point, $y=f(x)\in\mathbb{R}^n$, not a function, that can be expressed in terms of $x$. Can we differentiate a point as $ \frac{\partial y}{\partial x}$ or is this simply a common abuse of notation?
question 2: continuing the above, what is the proper way to write the derivative of $f$ at a particular point, say $p\in\mathbb{R}^m$? which of the following are correct, incorrect, or equivalent?
$$ df(p) \quad, \quad \frac{\partial f}{\partial x}\big|_p \quad, \quad \frac{\partial f(x)}{\partial x}\big|_p \quad, \quad \frac{\partial f(p)}{\partial p} \qquad? $$
I have a hunch that the "proper" notation for the derivative of some $f:\mathbb{R}^m \to \mathbb{R}^n$ is just $df$ and this is defined such that, at any arbitrary point $x\in\mathbb{R}^m$, it is given by $df(x)=\frac{\partial f(x)}{\partial x}$. Is this correct?
context: I posed this question in the context of real coordinate space(s), but I'm asking it with differential geometry in mind. My background is not in math and I recently started teaching myself some differential geometry and quickly realized I don't have a great grasp of proper mathematical notation.
edit: This question is related to one I asked on the physics page at this link
$\frac{\partial f}{\partial x}$ always means a partial derivative, which means that $x$ is a specific coordinate with respect to some choice of coordinates of the domain. It's sloppy and confusing to use it to mean the total derivative and I would avoid doing that. I would write $\boxed{ df }$ for the total derivative and $\boxed{ df_p }$ for the total derivative at a point $p$. You can see this notation used e.g. on the Wikipedia article for total derivative.
I would avoid writing $df(p)$ because the total derivative is itself another function, namely a linear map, which takes as input a tangent vector $v$ at the point $p$; in my preferred notation this can be written $df_p(v)$ but if you want to use $df(p)$ you'd have to use the more awkward $df(p)(v)$; in my opinion this doubling of parentheses is hard to read and should be avoided.
I would also avoid calling the total derivative the Jacobian; they are conceptually not the same thing. The total derivative is a linear transformation and the Jacobian is a matrix describing that linear transformation with respect to a suitable choice of bases.
Qiaochu Yuan
  • 419,620
  • I confess, I use to write $\mathrm{d}f(p)v$ or $\mathrm{d}f(p)\cdot v$, thinking of $\mathrm{d}f(p)$ as an operator acting on the vector $v$. At least, I definitely do not use $\mathrm{d}f(p)(v)$. – Didier Oct 11 '22 at 16:52
  • ok I think I inadvertently combined two similar questions into one by conflating partial vs total derivative. So you are saying that $df$ is the (total) derivative and it has matrix representation (in some basis) given by the jacobian $\frac{\partial f}{\partial x}$, correct? So then is $\frac{\partial f}{\partial x}$ indeed the proper way to write the jacobian or should it be $\frac{\partial f(x)}{\partial x}$? If we name $f(x)$ as $y=f(x)$, is it "proper" to write $\frac{\partial y}{\partial x}$? I.e. do we take partials of the function, $f$? or do we take partials of the output, $y=f(x)$? – J Peterson Oct 11 '22 at 17:13
    @JPeterson In terms of differential forms, it holds that $\mathrm{d}f = \sum_{i=1}^n \frac{\partial f}{\partial x_i} \mathrm{d}x_i$. If one writes $f=(f_1,\ldots,f_m)$, then the matrix representation of $\mathrm{d}f$ is $\left( \frac{\partial f_j}{\partial x_i}\right)_{1\leqslant i \leqslant n, 1\leqslant j \leqslant m}$. – Didier Oct 11 '22 at 17:24
    @JPeterson: again, $\frac{\partial f}{\partial x}$ is a partial derivative. I would write the Jacobian as $J(f)$ (and the Jacobian at a point as $J(f)_p$) to avoid confusion. The Jacobian is a matrix whose entries are partial derivatives, as Didier says. I would avoid the notation $\frac{\partial y}{\partial x}$ even for the partial derivative; this notation is common in physics but I think it is very confusing. – Qiaochu Yuan Oct 11 '22 at 17:29
    Isn't $d_pf$ more comfortable? Instead of $df_p(v)$ ist would read $d_pf(v)$. That's the way I've learned it. For example, the derivative if the $k$-th coordinate function $x_k$ at a point $p$ in direction $v$ reads $$d_px_k(v)$$ instead of $$d(x_k)_p(v).$$ – Michael Hoppe Oct 12 '22 at 16:13
  • I've never seen that notation before but I guess it's fine. It weirds me out a little because I would assume that a subscript indicates a tangent vector to differentiate along, so that notation clashes a little with the standard partial derivative notation $\partial_v$. – Qiaochu Yuan Oct 12 '22 at 16:16
