I have been doing some review with the goal of trying to understand as much as I can via universal properties and category theory (already feeling comfortable with the mundane way of doing things). What follows is what I wrote down in thinking about the operation of tensoring with a fixed module $(-)\otimes_AN$; in particular,
  • why it should be a functor, and
  • why it is right-exact.
My questions are at the end, and more generally I would welcome any feedback.
Everything here will be commutative and unital.
Let $A$ be a ring, and let $M$ and $N$ be $A$-modules. The functor $\mathbf{B}_{M,N}:\mathsf{Mod}_A\to\mathsf{Mod}_A$ defined by $$\begin{align*} \mathbf{B}_{M,N}(P)\;&=\;\mathrm{Bilin}(M,N;P)\\[0.05in] \mathbf{B}_{M,N}(\phi:P\to Q)\;&=\;\mathrm{Bilin}(M,N;P)\xrightarrow{\;\phi\,\circ\;}\mathrm{Bilin}(M,N;Q) \end{align*}$$ is (famously) representable. The representing object, unique up to unique isomorphism, is denoted by $M\otimes_AN$, and is referred to as the tensor product of $M$ and $N$.
Fix the module $N$, and consider the contravariant functor $\mathbf{T}_N:\mathsf{Mod}_A\to\mathsf{Mod}_A^{\mathsf{Mod}_A}$ defined by $$\begin{align*} \mathbf{T}_N(M)\;&=\;\mathbf{B}_{M,N}\\[0.05in] \mathbf{T}_N(\psi:M_1\to M_2) \;&= \; \widetilde{\psi}:\mathbf{B}_{M_2,N}\Rightarrow\mathbf{B}_{M_1,N} \end{align*}$$ where the natural transformation $\widetilde{\psi}$ is defined by $$\widetilde{\psi}_P:\mathrm{Bilin}(M_2,N;P)\xrightarrow{\;\circ \,(\psi,\,\mathrm{id}_N)\;}\mathrm{Bilin}(M_1,N;P)$$ Thus, a map $\psi:M_1\to M_2$ also induces a natural transformation $\widetilde{\psi}:h^{M_2\otimes_AN}\Rightarrow h^{M_1\otimes_AN}$, and by the enriched Yoneda embedding (??), we can see that such data is equivalent to a map $M_1\otimes_AN\to M_2\otimes_AN$. Thus, using only the universal property, $(-)\otimes_AN$ can be seen to be a (covariant) functor because a map $\psi:M_1\to M_2$ acts contravariantly on the spaces of bilinear maps, and hence covariantly on the representing objects.
First, I'd like to ask: am I correct that there is an "enriched Yoneda lemma" that works the way I cited above? Can someone provide a reference that explains it at a relatively basic level? To what extent do I need to apologize for referring to $\mathsf{Mod}_A^{\mathsf{Mod}_A}$?
Now for the question in the title, I would like to argue as follows for why $(-)\otimes_AN$ is right-exact:
If the map $\psi:M_1\to M_2$ is surjective, then it acts injectively on the spaces of bilinear maps (that is, two elements of $\mathrm{Bilin}(M_2,N;P)$ pull back by $(\psi,\mathrm{id}_N)$ to the same element of $\mathrm{Bilin}(M_1,N;P)$ if and only if they were the same to start with - (bi)linearity isn't even necessary here, just thinking about these as maps of sets shows this), and hence surjectively on the representing objects; that is, the induced map $M_1\otimes_AN\to M_2\otimes_AN$ is surjective. A short exact sequence $$M_1\xrightarrow{\;\psi\;}M_2\xrightarrow{\;\rho\;} M_3\longrightarrow 0$$ is equivalent to having a surjective map $\rho:M_2\to M_3$ and a surjective map $\psi:M_1\to\ker(\rho)$, and since $(-)\otimes_AN$ "preserves surjectivity" everything's good.
Of course, this argument is not rigorous as written; some sentence sounding approximately like
the enriched Yoneda embedding preserves epimorphisms
would have to be true. What is the (true) sentence I need?
Zev Chonoles
  • 129,973
  • I assume that you mean $Mod_{A}^{Mod_{A}}$ is the functor category (i.e. category of functors $Mod_{A}\rightarrow Mod_{A}$). Is it clear why this category is small? – DBS Jul 28 '13 at 04:10
  • @DBS: Yes, I mean the functor category; since $\mathsf{Mod}_A$ itself is not small, as far as I understand it the category $\mathsf{Mod}_A^{\mathsf{Mod}_A}$ shouldn't even exist, technically. That was part of what I was hoping to get rigorized about my argument :) – Zev Chonoles Jul 28 '13 at 04:16
    I think the enriched version of Yoneda that you refer to is here http://ncatlab.org/nlab/sho/enriched+Yoneda+lemma – DBS Jul 28 '13 at 04:44
  • In your case the functor category is not just a category but it is a $Mod_{A}$ enriched category (i.e. the Hom sets are not just sets but also A-Modules. – DBS Jul 28 '13 at 04:48
QUOTE:My questions are at the end, and more generally I would welcome any feedback.
$(-)\otimes_AN$ is a left adjoint functor of Hom$_\mathbb{Z}(N, -$)(see my answer to this question and the comments for it). Hence it preserves colimits(see, for example, Mac Lane's Categories for the Working Mathematician). Hence it is right exact.
Makoto Kato
  • 42,602
  • I agree that this is a correct argument for why $(-)\otimes_AN$ is right-exact, but I don't see how this is the rigorization of the argument I gave in my post. – Zev Chonoles Jul 28 '13 at 01:09
  • @ZevChonoles I think this proof explains very clearly why the tensor product is right exact. You said you would welcome any feedback. Sorry if this is not what you meant by a feedback. – Makoto Kato Jul 28 '13 at 01:26
  • Sorry, I misunderstood this as an answer to one of the questions I asked. Thanks for your feedback. – Zev Chonoles Jul 28 '13 at 01:44
