Suppose you are sampling from a probability distribution which contains a reciprocal:
$$f(x; \alpha, \lambda) = \begin{cases}\frac{\lambda \alpha^\lambda}{x^{\lambda+1}}~~x\geq \alpha;\\ 0 ~~~~~~\text{otherwise};\end{cases}$$
As explained here, the likelihood is maximised at $=min(\mathbf X)$.
The prior is assumed to be uniform $U[0,a] $
The posterior is proportional to the likelihood multiplied by the prior :
$$ \pi(\alpha|\mathbf x) \propto \frac{1}{a} \frac{\lambda^n \alpha^{n\lambda}} {\prod x_i^{\lambda+1}} ~~~~~~~~~ 0<\alpha<min(\mathbf X) $$
The integrand must be equal to 1:
$$ \int_0^{min(\mathbf x)} \frac{k}{a} \frac{\lambda^n \alpha^{n\lambda}} {\prod x_i^{\lambda+1}} d\alpha= 1 $$
$$ k = \frac{a\prod x_i^{\lambda+1}(n\lambda+1)}{\lambda^nmin(\mathbf x)^{n\lambda+1}} $$
Plugging this back into the posterior I get:
$$ \pi(\alpha|\mathbf x) = \frac{(n\lambda+1)\alpha^{n\lambda}}{min(\mathbf x)^{n\lambda+1}} $$
However I was expecting the posterior to be dependent on $a$, as well as $min(\mathbf x)$. Any suggestions on where I have gone wrong would be much appreciated!
If $\min(\mathbf x) \gt a$, then you need to redo your integral by adjusting the limits, and your posterior density will be supported on $[0,a]$. – Henry Aug 26 '22 at 00:06
