I found a way to prove this using Chebychev's theorem, are there ways to solve it without relying on this?
Asinomás
  • 105,651
Hint: Pick the largest $m$ so that $2^m \leq n$.
Isolate $\frac{1}{2^m}$ and add all the other fractions. Then your sum will have the form
$$\frac{1}{2^m}+\frac{k}{l}$$
where $2^m \nmid l$.
N. S.
  • 132,525
assume $\frac{1}{2}+\frac{1}{3}+...\frac{1}{n}=A$ with A is integer. Note that between $2 \leq i \leq n$, there must be i such that $i = 2^k$, with largest k thus $2^k| LCM(2,3,4,....,n)$ then each side(LHS and RHS) times $LCM(2,3,4,....,n)$ Obviously, LHS is even Look at RHS, $LCM(2,3,4,....,n) \cdot (\frac{1}{2}+\frac{1} {3}+...\frac{1}{n})$. we get all of the number are even except $LCM(2,3,4,....,n) \cdot \frac{1}{i}$ is odd. So, RHS is odd. Contradiction.
