In previous post, I got the answer that $\gcd \left(\frac{p^2+1}{2}, \frac{p^5-1}{2} \right)=1$, where $p$ is prime number.
I am looking for more general case, that is for $p$ prime,
When is $\gcd \left(\frac{p^r+1}{2}, \frac{p^t-1}{2} \right)=1$ ?
where $t=r+s$ such that $\gcd(r,s)=1$.
I am excluding the cases $r=1=s$.
In the previous post, it was $r=2,~t=5$. So $t=5=2+3=r+s$ with $s=3$ so that $\gcd(r,s)=1$.
In this current question:
Since $\gcd(r,s)=1$, we also have $\gcd(r,t)=1$. I have the following intuition:
Case-I:
Assume $r$=even and $s$=odd so that $\gcd(r,s)=1$ as well as $\gcd(r,t)=1$. We can also assume $r$=odd and $s$=even.
I think the same strategies of previous post can be applied to show that $$\gcd \left(\frac{p^r+1}{2}, \frac{p^t-1}{2} \right)=1.$$
Case II:
The problem arises when both $r$ and $s$ are odd numbers so that $t=r+s$ is even.
If I take $r=3, ~s=5$, then $t=8$.
For prime $p=3$, $\frac{p^r+1}{2}=\frac{3^3+1}{2}=14$ and $\frac{p^t-1}{2}=\frac{3^8-1}{2}=3280$ so that the gcd is $2$ at least.
For other primes also we can find gcd is not $1$.
So I think it is possible only for Case I, where among $r$ and $s$, one is odd and another is even so that $t$ is odd.
In other word, $t$ can not be even number.
But I need to be ensured with a general method.
So the question reduces to
How to prove $\gcd \left(\frac{p^m+1}{2}, \frac{p^n-1}{2} \right)=1$ ?
provided $\gcd(m,n)=1$ and $n$ is odd number and $p$ is prime number.
Thanks
