Let $U_{1}, U_{2}, U_{3}$ be i.i.d. random variables which are uniformly distributed on (0,1). Let $X = \min(U_{1}, U_{2})$ and $Y = \max(U_{2}, U_{3})$
(a) Find $P(X< x, Y < y)$ for all x,y in $\mathbb R$
(b) Find $P(X = Y)$
(c) Find $E[XI_{\{X=Y\}}]$ where $I_{A}$ is the indicator function of A.
(a) I found the PDFs of X and Y, i.e. $f_X(x)=2(1-x), f_Y(y)=2y$ using order statistics. I wanted to find the joint density and then integrate it to get the joint CDF, but I'm not sure how to find the joint density given that X and Y are dependent (?). Can someone please help?
b) $$P(X=Y)=P( \min(U_1,U_2)= \max(U_2,U_3))=P( \min(U_1,U_2)=U_2, \max(U_2,U_3)=U_2)=P(U_1>U_2>U_3)=\frac{1}{6}$$ (Since there are 6 (3!) ways to order 3 of these variables, I'm neglecting the possibility of $U_1=U_2=U_3$). Is this correct?
c) Isn't it the same as part (b)? I'm confused, please help.
Jason
  • 2,065
Tapi
  • 1,688
(a). The joint distribution $F(x, y) := P(X < x, Y < y)$ clearly depends on the value of $(x, y)$:
  • If $x > 1$ and $y > 1$, then clearly $F(x, y) = 1$.
  • If $x \leq 0$ or $y \leq 0$, then clearly $F(x, y) = 0$.
  • If $0 < x \leq 1$ and $y > 1$ then $$F(x, y) = P(X < x) = 1 - P(\min(U_1, U_2) \geq x) = 1 - (1 - x)^2 = 2x - x^2.$$
  • If $x > 1$ and $0 < y \leq 1$, then $$F(x, y) = P(Y < y) = P(U_2 < y)P(U_3 < y) = y^2. $$
The only non-trivial case is when $0 < x \leq 1$ and $0 < y \leq 1$, for which by the independence assumption: \begin{align} & P(X < x, Y < y) = P(\min(U_1, U_2) < x, \max(U_2, U_3) < y) \\ =& \int_0^1 P(\min(U_1, z) < x, \max(z, U_3) < y)dz \tag{1} \\ =& \int_0^1 [P(\max(z, U_3) < y) - P(\min(U_1, z) \geq x, \max(z, U_3) < y)]dz \\ =& \int_0^1 P(\max(z, U_3) < y)dz - \int_0^1P(\min(U_1, z) \geq x, \max(z, U_3) < y)dz \\ =& \int_0^y P(U_3 < y) dz - \int_0^1P(\min(U_1, z) \geq x, \max(z, U_3) < y)dz \\ =:& y^2 - I \end{align}
For the integral $I$, if $x \geq y$, then the integrand is $0$ whence $I = 0, F(x, y) = y^2$. If $x < y$, then \begin{align*} I = \int_0^1P(\min(U_1, z) \geq x, \max(z, U_3) < y)]dz = \int_x^y P(U_1 \geq x, U_3 < y) dz = (1 - x)y(y - x). \end{align*} It then follows that $F(x, y) = y^2 - y(1 - x)(y - x) = xy + xy^2 - x^2y$. For the veracity of equation $(1)$, refer to Theorem $20.3$ of Probability and Measure by P. Billingsley.
The above calculations can then be summarized as \begin{align} F(x, y) = \begin{cases} 0 & (x, y) \in \{(u, v): u \leq 0\} \cup \{(u, v): v \leq 0\}, \\ xy + xy^2 - x^2y & (x, y) \in \{(u, v): 0 < u < v < 1\}, \\ y^2 & (x, y) \in \{(u, v): 0 < v \leq u < 1\} \cup \{(u, v): u > 1, 0 < v \leq 1\}, \\ 2x - x^2 & (x, y) \in \{(u, v): 0 < u \leq 1, v > 1\}, \\ 1 & (x, y) \in \{(u, v): u > 1, v > 1\}. \end{cases} \end{align}
(c). (c) is clearly different from (b), which is identical to $E[I_{\{X = Y\}}]$ (i.e., without multiplying $X$). To evaluate $E[XI_{\{X = Y\}}]$, note that it's the expectation of a non-negative random variable, therefore, \begin{align} E[XI_{\{X = Y\}}] = \int_0^\infty P[XI_{\{X = Y\}} > t] dt = \int_0^1 P[XI_{\{X = Y\}} > t] dt = \int_0^1 P[X > t, X = Y] dt. \tag{2} \end{align} The probability in the integrand can be evaluated in the same manner as determining $F(x, y)$, for which we apply the Theorem leading to $(1)$ again:
\begin{align*} & P[X > t, X = Y] = P[\min(U_1, U_2) > t, \min(U_1, U_2) = \max(U_2, U_3)] \\ =& \int_0^1 P[\min(U_1, s) > t, U_1 \geq s, U_3 \leq s] ds \\ =& \int_t^1 P[U_1 > t, U_1 \geq s, U_3 \leq s] ds \\ =& \int_t^1 P[U_1 \geq s, U_3 \leq s]ds \\ =& \int_t^1 s(1 - s)ds = \frac{1}{6} - \frac{1}{2}t^2 + \frac{1}{3}t^3. \end{align*}
Substituting it into $(2)$, it then follows that \begin{align*} E[XI_{\{X = Y\}}] = \int_0^1 \left(\frac{1}{6} - \frac{1}{2}t^2 + \frac{1}{3}t^3 \right) dt = \frac{1}{12}. \end{align*}
Zhanxiong
  • 14,040
For finding the joint CDF, it's probably easiest to attack it directly and break it into components rather than trying to sort out the joint PDF from the marginal distributions.
$\begin{eqnarray} P(X < x, Y < y) & = & P(X < x | Y < y) P(Y < y) \\ P(X < x | Y < y) & = & 1 - P(X \geq x | Y < y) \\ & = & 1 - P(U_1 \geq x \land U_2 \geq x | U_2 < y \land U_3 < y) \\ & = & 1 - P(U_1 \geq x) P(U_2 \geq x | U_2 < y) & \textrm{by independence} \\ P(Y < y) & = & P(U_2 < y \land U_3 < y) \\ & = & y^2 \end{eqnarray}$
I'll leave it to you to piece everything together from there, and maybe do some calculus to prove to yourself that you get the right marginal distributions as a result. You can then apply the joint CDF to parts (b) and (c) as necessary.
ConMan
  • 24,300
  • Can you explain how you got the last equality using independence while simplifying $P(X<x | Y<y)$? – Tapi Aug 04 '22 at 16:39
  • Sure. First, since nothing in the probability involves $U_3$, we can just drop it from the conditional. Then we can break up $P(U_1 \geq x \land U_2 \geq x | U_2 \leq y)$ into $P(U_1 \geq x | U_2 \geq x \land U_2 \leq y)P(U_2 \geq x | U_2 \leq y)$, and the first term doesn't depend on $U_2$ so we can drop that conditional too. – ConMan Aug 04 '22 at 23:20
