-1
My question here is pretty basic, so I apologize in advance if there is a simple answer.
INITIAL QUESTION
If $A$ is a positive integer and $\gcd(pq,A)=1$ holds (where $p$ and $q$ are primes), does it follow that $\gcd(p,A)=1$ and $\gcd(q,A)=1$?
MY ATTEMPT
Let $A$ be a positive integer, and suppose that $\gcd(pq,A)=1$ holds (where $p$ and $q$ are primes).
Without loss of generality, suppose that $\gcd(p,A) > 1$. Since $p$ is prime, then we consider two cases:
  • Case 1: $A < p$
Since $p$ is prime, $A < p$ would imply that $\gcd(p,A) = 1$, contradicting our assumption.
  • Case 2: $A \geq p$
Since $p$ is prime, and since $\gcd(p,A) > 1$, then $A \geq p$ implies that $\gcd(p,A)=p$, which further means that $p \mid A$. This implies that we can write $A = pa$, for some positive integer $a$. Thus, we obtain $$\gcd(pq,A)=\gcd(pq,pa)=p\cdot\gcd(q,a) \geq p \geq 2,$$ which contradicts $\gcd(pq,A)=1$.
QED
FINAL QUESTION
Does the proof above generalize to a valid argument for the following proposition?
  • If $B$ is a positive integer and $$C = \prod_{i=1}^{\omega(C)}{p_i}$$ is squarefree such that $\gcd(B,C)=1$, does it follow that $\gcd(B,p_i)=1$ for each $i$, $1 \leq i \leq \omega(C)$?
Just note that any common divisor of $p$ and $A$ is also a common divisor of $pq$ and $A$. So $\gcd(pq,A)\ge \gcd(p,A) \ge 1$. But you're given that $\gcd(pq,A)=1$.
By the way $p$ and $q$ don't have to be primes for the result to hold.
paw88789
  • 40,402
