This is more of a post I wanted to share. I have decided to tackle the following integral via contour integration:
$$\int_{-\infty}^{\infty}\operatorname{sech}\left(x\right)\ln\left(\cosh\left(x\right)\right)dx.$$
Proof. Let that integral equal $I$. Let $$f(z) = \frac{\text{Log}{(z+i)}}{z^2+1},$$ where Log represents the principal logarithm. We shall traverse, in a counterclockwise direction, a path $C$ defined by
$$C = \left[-R,R\right] \cup \Gamma,$$
which is a large semicircle of radius R above the real axis.
We can express the contour integral over $C$ as
$$\oint_Cf(z)dz = \int_{-R}^{R}f(z)dz + \int_{\Gamma}f(z)dz$$
Notice the only singularity that resides in $C$ is $i$. Taking the residue at that pole yields
$$\oint_Cf(z)dz = 2\pi i\text{Res}{(f(z),i)} = 2\pi i \lim_{z \to i}f(z) = \pi\ln{(2)} + i\frac{\pi^2}{2},$$
after evaluating the limit and doing some algebra. By transitivity and taking the limit as R goes to infinity, we see that
$$\lim_{R \to \infty} \int_{-R}^{R}f(z)dz + \lim_{R \to \infty} \int_{\Gamma}f(z)dz = \pi\ln{(2)} + i\frac{\pi^2}{2}.$$
Let's call the first and second integrals $I_1$ and $I_2$, respectively. Rewriting $I_1$ gives us
$$\eqalign{\int_{-R}^{R} \frac{\text{Log}(z+i)}{z^2+1}dz &= \int_{-R}^0 \frac{\text{Log}(z+i)}{z^2+1}dz + \int_{0}^R \frac{\text{Log}(z+i)}{z^2+1}dz \cr &= \int_{R}^0 \frac{\text{Log}(-y+i)}{(-y)^2+1}d(-y) + \int_{0}^R \frac{\text{Log}(z+i)}{z^2+1}dz \cr &= \int_{0}^R \frac{\text{Log}((i-y)(i+y))}{y^2+1}dy \cr &= i\frac{\pi^2}{2} + \int_0^R \frac{\ln{(1+y^2)}}{1+y^2}dy\cr}$$
after doing some basic manipulations and integration.
Note if $|z| = R$, then $z$ is on $R$. Dealing with $I_2$ as $R$ approaches infinity, consider the following inequalities:
$$|\text{Log}(z+i)| = |\ln|z+i| + i\text{Arg}(z+i)| \leq ||z+i| + i\pi| \leq R+1+\pi;$$
$$\left|z^2+1\right| \geq \left|\left|z^2\right|-1\right| = R^2 - 1.$$
By applying the ML-Inequality and Squeeze Theorem, we get
$$0 \leq \left|\int_{\Gamma}f(z)dz\right| \leq |f(z)|\left(\frac{2\pi R}{2}\right) \leq \frac{R+1+\pi}{R^2-1}$$
$$\lim_{R \to \infty} 0 \leq \lim_{R \to \infty} \left|\int_{\Gamma}f(z)dz\right| \leq \lim_{R \to \infty} \frac{R+1+\pi}{R^2-1}$$
$$0 \leq \lim_{R \to \infty} \left|\int_{\Gamma}f(z)dz\right| \leq 0.$$
This implies that
$$\lim_{R \to \infty} \int_{\Gamma}f(z)dz = 0.$$
Going back and taking R to infinity, we see that
$$\eqalign{ \pi \ln{(2)} + i\frac{\pi^2}{2} &= i\frac{\pi^2}{2} + \int_0^{\infty} \frac{\ln{(1+y^2)}}{1+y^2}dy + 0 \cr \pi \ln{(2)} &= \int_0^{\infty} \frac{\ln{(1+y^2)}}{1+y^2}dy. \cr }$$
Letting $y = \sinh{(x)}$, we get
$$ \int_0^{\infty} \frac{\ln{(1+y^2)}}{1+y^2}dy = \int_0^{\infty}\frac{\ln{(\sinh^2{(x)}+1)}\cosh{(x)}}{\sinh^2{(x)}+1}dx = 2\int_0^{\infty}\operatorname{sech}\left(x\right)\ln\left(\cosh\left(x\right)\right)dx. $$
Since $\operatorname{sech}\left(x\right)\ln\left(\cosh\left(x\right)\right)$ is an even function, we see that
$$2\int_0^{\infty}\operatorname{sech}\left(x\right)\ln\left(\cosh\left(x\right)\right)dx = \int_{-\infty}^{\infty}\operatorname{sech}\left(x\right)\ln\left(\cosh\left(x\right)\right)dx.$$
Therefore,
$$\int_{-\infty}^{\infty}\operatorname{sech}\left(x\right)\ln\left(\cosh\left(x\right)\right)dx\ =\ \pi\ln\left(2\right).$$
Q.E.D.
Let me know if you know any other strategies you have. If you have any suggestions on optimizing the solution or find any errors, please do not hesitate to share them with me!
P.S. Does anyone know how to draw a semicircle contour using LaTeX? Like using a Tikz package or something?
Accelerator
  • 4,923
More directly
\begin{align} &\int_{-\infty}^{\infty}\operatorname{sech}(x)\ln\left(\cosh x \right)\ dx \\ =& \ 2\int_{0}^{\infty}\ln\left(\cosh x \right)\ d(-\tan^{-1}\text{csch} \ x) \\ \overset{ibp}=&\ 2\int_{0}^{\infty}\tanh x\ \tan^{-1}(\text{csch} \ x)\ dx \overset{t = \text{csch} \ x }= 2\int_0^{\infty}\frac{\tan^{-1}t}{t(1+t^2)}dt\\ =& \ 2\int_0^{\infty}\int_0^1 \frac{1}{(1+t^2)(1+y^2 t^2)}dy dt = \pi\int_0^1 \frac{1}{1+y}dy =\pi\ln2\\ \end{align}
Quanto
  • 97,352
  • That is an amazing solution! I like how you thought of that arctangent csch(x) function. Thank you! – Accelerator Jul 24 '22 at 06:58
  • @Accelerator - Thanks. I guess I’m just familiar with it as one of the anti’s for $\text{sech}\ x$, which admittedly is less known – Quanto Jul 24 '22 at 16:08
