I wanted to know how can i prove that if
$xy+yz+zx=1$, then
$$ \frac{x}{1+x^2}+\frac{y}{1+y^2}+\frac{z}{1+z^2} = \frac{2}{\sqrt{(1+x^2)(1+y^2)(1+z^2)}}$$
I did let $x=\tan A$, $y=\tan B$, $z=\tan C$
given $xy+yz+zx =1$ we have $\tan A \tan B+ \tan B \tan C+\tan C \tan A=1$
$\tan C(\tan A+\tan B)=1-\tan A \tan B$, or $\tan(A+B)=\tan(\pi/2 -C)$ we have $A+B+C=\pi/2$.
what to do now?
Any help appreciated.
thanks.
Shobhit
  • 6,902
    So your question is whether this problem is tough? Because your title indicates exactly that (it also indicates, by duplication of the question mark, that you don't really believe it). – celtschk Jul 21 '13 at 09:55
    @celtschk: Maybe the question is whether it is algebric. – Chris Eagle Jul 21 '13 at 11:21
HINT:
$$\frac x{1+x^2}=\frac {\tan A}{1+\tan^2A}=\frac{2\sin A\cos A}2=\frac{\sin2A}2$$
Now , $$\sin2A+\sin2B+\sin2C=2\sin(A+B)\cos(A-B)+2\sin C\cos C$$
$$=2\sin\left(\frac\pi2-C\right)\cos(A-B)+2\sin C\cos C$$
$$=2\cos C\{\cos(A-B)+\cos(A+B)\}$$ as $\sin C=\sin\{\frac\pi2-(A+B)\}=\cos(A+B)$
$$\implies \sin2A+\sin2B+\sin2C=2\cos C\cdot2\cos A\cos B$$
and $$\frac1{\sqrt{1+x^2}}=\frac1{\sec A}=\cos A$$
    do you people even blink, before answering o_o. – Shobhit Jul 21 '13 at 04:59
  • @Shobhit, not sure if I clearly understood your statement. But have you noticed $\tan(A+B)=\tan\left(\frac\pi2-C\right)\implies A+B=n\pi+\frac\pi2-C$ where $n$ is any integer. The above proof hold if $n=2m$(even). What about $n=2m+1$(odd)? – lab bhattacharjee Jul 21 '13 at 05:09
  • @Shobhit: This is a really cool problem. May I know the name of the book you are studying from? – Prism Jul 21 '13 at 06:11
  • @Shobhit, if $n=2m+1,$ $$\tan\left(A+B\right)=\tan{(2m+1)\pi+\frac\pi2-C}=\tan\left(\frac\pi2-C\right)=\cot C,$$ but $$\sin\left(A+B\right)=\sin{(2m+1)\pi+\frac\pi2-C}=-\sin\left(\frac\pi2-C\right)=-\cos C$$ and $$\cos\left(A+B\right)=\cos{(2m+1)\pi+\frac\pi2-C}=-\cos\left(\frac\pi2-C\right)=-\sin C$$ – lab bhattacharjee Jul 21 '13 at 06:33
  • @labbhattacharjee the maths written is not clear mind to take a look. – Shobhit Jul 21 '13 at 07:33
  • @Shobhit, not sure why the comment formatting got corrupted. My point is if $n=2m+1,\sin(A+B)=-\cos C$ and $\sin C=-\cos(A+B)$ I am trying to figure out what happens if we consider the general value of $A+B+C$ which is $n\pi+\frac\pi2$ – lab bhattacharjee Jul 21 '13 at 08:58
  • @Shobhit, btw another similar problem is $$\sum \frac x{1-x^2}=4\prod \frac x{1-x^2}$$ if $xy+yz+zx=1$ – lab bhattacharjee Jul 21 '13 at 09:01
  • @labbhattacharjee its the same, let $x=tanA, y=tanB, z=tanC$ ,multiply and divide L.H.S by 2 to get L.H.S =$\frac12(tan2A+tan2B+tan2C)$, also solving $xy+yz+zx =1$, we get $A+B+C=\frac\pi{2}$ , applying $tan(2A+2B)=tan(\pi-2C)$ or $tan2A+tan2B+tan2C=tan2Atan2Btan2C$, which is R.H.S on simplifying.Good question. – Shobhit Jul 21 '13 at 09:11
The accepted answer by `lab bhattacharjee' is perfectly fine. For what it's worth, there's a nice geometric view that might enrich this nearly-4-year-old post a tiny bit.
The identity to be proven is, given $\alpha + \beta + \gamma = \frac{\pi}2$, $$ \frac12 \big( \sin 2\alpha + \sin 2\beta + \sin 2\gamma \big) = 2 \cos\alpha \cdot \cos\beta \cdot\cos\gamma$$
Consider an acute triangle $\triangle MNP$ as shown in the figure, with its circumcenter denoted as point $O$. Without loss of generality, take the circumcircle as the unit circle. That is, $$\text{diameter}~~ \overline{PP'} = 2 \qquad \text{radius}~~ \overline{OM} = \overline{ON} = \overline{OP} = 1$$
By definition, all angles are acute so that any one of them can be split into two parts, say, $\angle PMN = \alpha + \beta < \frac{\pi}2$, with a remaining complement $\gamma > 0$, as in $$\alpha + \beta + \gamma = \frac{\pi}2$$
The desired identity comes from calculating the area $\mathcal{A} \equiv |\triangle MNP|$ in two different ways:
$$\begin{align} &\text{RHS}: & \mathcal{A} &= \frac12 \cdot \overline{MP} \cdot \overline{MN} \cdot \sin(\angle PMN ) \\ &\text{LHS}: & \mathcal{A} &= |\triangle OMP| + |\triangle ONM| +|\triangle OPN| \end{align}$$
For the RHS, we have $$\overline{MP} = 2\cos\alpha \qquad \overline{MN} = 2\cos\beta$$ since point $O$ is the circumcenter (e.g. $\overline{MO} = 1$ and $\triangle MOP$ is an isosceles, $\overline{MP}$ is bisected by the height to point $O$). That is, $$\begin{align} &\text{RHS}: & \mathcal{A} &= \frac12 \cdot \overline{MP} \cdot \overline{MN} \cdot \sin(\angle PMN ) \\ && &= \frac12 \cdot 2\cos\alpha \cdot 2\cos\beta \cdot \sin(\alpha + \beta) \\ && &= 2\cos\alpha \cdot \cos\beta \cdot \sin(\frac{\pi}2 - \gamma) \\ && &= 2\cos\alpha \cdot \cos\beta \cdot\cos\gamma \end{align}$$
Now, for the LHS we again apply the Law of Sines to each of the small triangles. For example, $$\begin{align} \triangle{NOP} &= \frac12 \cdot \overline{ON} \cdot \overline{OP} \cdot \sin(\angle NOP) \\ &= \frac12 \cdot 1 \cdot 1 \cdot \sin(\pi - \angle NOP') \\ &= \frac12 \sin(\pi - 2\gamma) \end{align}$$ since $\angle NOP'$ is the central angle for the inscribed angle $\gamma$ (and $\triangle PMN$ is acute so $O$ is "inside"). Therefore, we have $$\triangle{NOP} = \frac12 \sin 2\gamma \qquad \text{and similarly} \qquad \triangle{POM} = \frac12 \sin 2\alpha \quad \triangle{MON} = \frac12 \sin 2\beta$$ which sum to the LHS of the desired identity. Note how this proof (splitting a triangle into 3 inner ones) naturally exhibits the cyclic nature (3-fold symmetry) of the identity. $~~~~~$Q.E.D.
When the triangle is obtuse, the proof is similar: one of $\alpha, \beta, \gamma$ is negative, which corresponding 'inner' triangle becomes `outer', and its effective area is also negative). For the case where two of $\alpha, \beta, \gamma$ are negative, unfortunately the notion of a triangle breaks down (unless one considers projective geometry, I guess).
P.S.
I definitely have seen this triangle-splitting analysis before at various places, with respect to any general point and not just the circumcenter. The corresponding algebraic expression involves more than 3 angles.
